Weird noise from the rear
    I have a question about a noise that is coming out of the passenger ear end of my car. Whenever i go over a bump or make a slow turn i hear this sound thats sounds similar to water boiling(gargaling) or loose nut. It really pisses me off. If anyone might know what the problem could be, please help me out. Im not 100 percent sure if its from the passenger side rear end but it sounds like it is. Thanks
    Could need a new rear shock mount. Also, check your heat shield, mines loose and sounds kinda like that. Or you could just have a loose bolt somewhere.
      Maybe a loose diff bolt? Like stated above, check your RSM's too.
        I just had this exact same problem. Mine turned out to be a worn shock mount, I had two new rear shocks and two new rear shock mounts put in. It was about $300 with labor. You might also want to check and make sure the battery is secured properly cuz it could be rattling.
          Maybe you ran over a rodent and it's still trying to escape from inside the wheel well. jk.
          Most likely your shocks, the Benz had this problem. And might as well get new mounts while you mess with the shocks. Good luck.
