i think i have confussed u all ....sorry...what i am trying to say is i have a 97 m3 the gap between the wheel and the arch on the rear right hand side is non existant the gap on the rear left hand side is about 3 fingers i have had the springs and rubbers replaced but its still the same please help
stupid new female owner with problem
My 98 sedan is the same way, although not quite as pronounced.
Both front and back left side measure around a quarter of an inch higher than the right. (Measured from center of wheel straight up to fender lip.) I've read several posts on bimmerforums.com that state that this is normal (the bentley manual states that the ride height between left and right sides shouldn't vary by more than 3/8" or something like that.)
I surmise that the higher ride height on the left is to compensate for the driver's weight (if you sit in the car, the difference should be significantly less).
That said, three finger's difference is definitely out of spec-- three of my fingers is about 2 inches. Is the car parked on level ground when you measure? Most garage floors are not quite level...
