now that i think of it.. if u have power heated vaders.. get some new seat.. i know u can save a shitload right there.. i wanna find some replacement leather recaros if i can.. but the prices are just outragous..
48 pounds ligher!!!!
I would also never put fix a flat in my car if I cared about the tires.
I've heard it does nasty things to tires and you should probably replace them after using it. If the hole is small enough, you can probably reuse the tire normally.
Anyone else heard negatives about fix-a-flat? The E46 M3 guys pretty much agree that call a flatbed instead of using their M-mobility kit (glorified fix-a-flat) unless they are in the middle of the woods or something.
Fix a Flat is a terrible solution!!! It is highly flammable and many shops will even charge you extra to work on a tire that has had Fix a Flat in it because of the risks. SpecVcepS is right! You will never be able to balance that tire again. So fix a flat might get you home but you may as well order a new tire on your way.
