My homemade "dyno"
    My homemade "dyno"
    I recently thought up and tested an idea to test the efficiency of my 95 m3. I set the cruise control at a highway speed and reset the trip computer's average fuel at a certain point (x overpass) and cruised for several miles to "y" overpass (tough to do in Atlanta without interrupting the cruise). It helps if temps are similar.
    I tested a before and after run of about 10 miles running at 75 mph and got 25.6mpg before I changed out my worn Bosch Platinum +4's. After changing to NGK BKR6EQUP's, mpg's increased to 26.4 at about the same temp and fuel load.
    I have not yet tested for repeatibility of this 26.4, but I'd bet it's a pretty accurate reading for seeing how efficient my engine's running.
    What do you guys think?
    The computer is WAY off... have you ever filled up and checked your distance? it's says something like 407+... have you ever gotten that?
