problems after clutch install
    Had a new clutch installed...now have problem, the car stalls after release of clutch...anyone have any suggestions to what may cause this???
    Wow, no matter how hard you rev it?
    Like, if you let it out super duper slowly and ride the thing to death, it'll just automatically stall?
    Does it stall in neutral too?
      Sure does....
      rolls in neutral with the motor off
      wont roll in gear
      Sounds like a vacuum leak...can't blip the throttle w/o stalling.
      Possibly from tilting the motor to ge the top bolts...
      Checking that now
        you're screwed just sell me the car for real cheap.
          Uber,
          May just do! Gotta dollar?
          The current thinking is that the frickin disc is in backwards. They are removing the tranny as i write to verify.
            what was the reason for failure?
              jeez.. how does a "trained proffesional" put in a clutch disc backwards
                As he had never done a BMW before he didn't realize that the orientation is indicated by the words Motorside (in german) written on the disc...the other side has an M stamped on it and thats what he used as the orientation indicator.
                He pulled the tranny out, reversed the disc, and all is well.
                  still though...wow. I'm glad to here everything worked out for you.
                  He just wasted a whole lot of his time and yours with a 2 minute mistake.
                  That's gotta be a bad feeling.
                    Motor seite? not exactly a brain twister
                      Pretty much what I was thinking....I had even pointed it out to him before install!
                      But hey, he did it twice and thanked me, so what can I say?
