Trying to join the club
    hey i have a blown m3 motor and i am going to try to fix it and put it in my car...But listen to this on a mishift the guy managed to bend all 24 valves damage all 6 pistons and put a few cracks on the top of the block. In conclusion i need to do a lot of work i am going to try to deck the motor and bore it a little which should fix the block. I will but my cams that should come in and port and polish the motor. New valves and springs...
    My questions are where would you buy the valves, what type of piston should i put in there, what size fuel injectors, will my spark plugs off a 95 325 fit a 95 m3 motor? Can i just reprogram my chip and what company would you reccomend?
    Thanks in advance
    John
    Damn man sounds like a project. I would look at the specs of the Euro engine and bore and stroke to match - thery have a little more displacement than the US 3.2 and run at a higher compression. I would build it bulletproof to match the Euro specs and then try to get some custom software from Jim C or someone.
    Good luck - I definitley want updates.
    Also Jeff at Rennen in Tampa might be a good source for info. From what I know and have heard he knows these cars better than most.
