OK, I finally got my "Brake Circuit Failure" warning on the OBC. I almost felt that this was a right of passage with these cars because it seems to happen so frequently.
I swung by the $tealership and bought the new switch for $30 and was about to do the install. Before the install, I ran a google search on the problem to look for some instructions and I found another lesser know issue that causes this warning. After looking at my car, this is definitely the case.
Here is what happened:
The brake lamp bulb socket was not making very good contact with the contact on the car. Eventually, the arcing created a hole in the contact. To fix it, I cleaned up the contact in the housing. I also cleaned the socket contact up quite a bit. So far, so good.
We'll see if this works long term, but I am concerned about the small hole that is in contact now.
Just thought that I'd post this as an FYI.
I also now have an extra switch if anyone wants it.
