'99 3.2L Oil Drain Plug Torque Specs
    By doing a search of this forum I found a DIY link for changing oil. The oil change was done on a 3.0L engine and the torque spec for the oil drain plug is said to be 18 ft-lbs.
    Is that torque spec the same for the later, 3.2L engine. I'm assuming it is, but just want to double check.
    I'm not new to changing my own oil, I've done it for years on my VWs. I'm just taking a little more care with the BMW because the outcome can be vastly more expensive if you don't do it right.
    TIA,
    FLi
    Yeah, that's the spec for all E36's, as far as I know. I go by the Bentley manual, and that's what it has.
    TIA,
    FLi
      This is from BMW's torquespecs accoding the BMW:
      1AZ Oil drain plug
      All M12 x 1.5 25 Nm
      All M18 x 1.5 35 Nm
      All M22 x 1.5 60 Nm
        Norris14 and Sirus -
        Thanks Gents!
        FLi
