Brake Dust
    Brake Dust
    Has anyone found a tried and true method of reducing brake dust on your rims? DO Kleen Wheels work on the E36 M3? Any pads out there that are dust reduced? Just curious...
    Use a less dusty pad. You can use Kleen wheels brake dust covers, but BMW is HIGHLY against them, as they greatly increase your chance of warped rotors. I am not fimilar wtih too many names of aftermarket pads that are reduced dust-wise, but I am sure there are plenty of people here who know :P
      I have the Pagid pads and they generate very little dust. What I do to mitigate this problem, is wax the wheels every other time I wax the car. I find that there is generally less brake dust on the wheels, and whatever little is there comes off very easily. As for kleen-wheels and other cover products, you must be careful because there is no way for the heat to escape that area of the well quickly and easily. One splash in a puddle and you may have warped rotors.
        I have a 95 M3 and now use metalmaster pads. they are inexpensive ($60 front and $40 rear) for a set and have greatly reduced my dust. they use more metal than regular pads and work well for track or daily driving. give them a shot!
          you could also look into axxis ultimates pads. they are ceramic, while they still do dust like all pads, the dust from these is a much lighter color, so the rim doesn't show its dirtyness as much.
            i tried "wheel wax" and it worked pretty well. took a while to put on, but after that, there wasn't too much brake dust to be found for quite some time. and it smells really good
              Are you huffing wheel wax? that can't be good! j/k
                axxis ultimates dust about 1/2 as much as stock. Hawk HPS will dust 1/4 of stock, and its a lighter color. But axxis have better initial bite. I would never do kleen wheels, get a different set of pads and your dust problems will be reduced.
                  HTR wheelwax works great
                    Bleh, Just clean your car weekly damn it! :smash:
                      wellll.......
                      :dance:
                      heh, you can't avoid smelling it...smells like pina colada
                        Zymol smells like that. But meguires smells the best!
