Wheel/tire suggestions for $1500
    Hey guys, since Im redoing my suspension I figure I should upgrade the most important part of the car- the tires. Along with those tires is going to come some new wheels. Im looking for a staggered 18x8.5 front and 18X9.5 rear with 225/40-18 front and 245/35-18 rear. Will these be fine with Eibach springs and no fender rolling?
    ADR Msport- http://www.wheelsnext.com/prod_imgs/img-399-131-1-small.jpg
    Axis Supermesh- http://www.wheelsnext.com/prod_imgs/img-250-154-1-small.jpg
    Other suggestions for wheels and tires for around $1500 ( I can go a little higher) would be appreciated. Thanks!
    I'm not sure if ADR are the best brands but i've always thought the msport rims looked hot.
      If I do 18x8.5 ET35 with 225/40-18 all around will I rub with an Eibach 1" drop?
        You shouldnt rub with that setup..depending upon the tires. I know s03's run wide, though i still think those wouldnt rub.
        I would get the axis-supermesh out of the two you posted. Try and find wheels that arent terribly heavy..i think your brakes would appreciate it.
        -RIchard
          no rubbing at al but you must have te right ET value
          i'm running on 18" HARTGES with 225/40R18 in front and 255/35R18 at the rear
          no problems at all
