Installing Brembo Cross Drilled Slotted rotors
    Guys,
    Just purchased a set of front and rear cross drilled /slotted brembo rotors for my ride (98 M3 Sedan). Has anyone had any installation experiences? Any thing in particular I need to be aware of ( tools, etc)? Really appreciate it.
    Thanks
    E
    pretty easy, just make sure you also get new pads, i would say get axis ultimates.. and make sure you don't mix up the right and left side, they are directional..
      Its just like a normal brake job.... cept your not using oem rotors/pads...
        Guys,
        DO I really need new pads or can I use the ones I have on there currently?
        Thanks
          How worn are they? I always put new pads/rotors on regardless, its prob redundant, but thats what I like, a fresh start each time...
            when ou install new disks always install new pads !!! the old ones are wear acoording your old disks en than the will try to make the same wear in the new ones !!!
              Thanks guys for all the replys and feedback.
              Appreciate it.
