Umnitza Depo install??
    OK first how things look:
    Stock wire harness has two wires for each High and Low beam bulbs. These connectors just pop the bulb into the back of the stock headlight housing.
    The Depo lights are wired internally, and the internal wiring for high, low, and daylight running bulb exit the Depo's in a circular PIN housing. Four pins, a ground, high, low, Daylight running. THey are male connectors.
    What i received was, a relay kit for the Angel eye light boxes.
    A> And i also got a set of (2) 16"approx bundled wire kit with a white and brown wire with black female connector. And a brown and yellow wire with grey female connector. The wires terminate with a female crimp type connection (assuming they attach to the back of the Depo light male circular PIN housing)>
    B>
    I also received a smaller 7" bundled wire setup with yellow/brown wires with grey male connector, and grey/white wires with black male connector. Also there is a smaller black connector with red tip and yellow boot seal. All the wires lead into a circular black thread in, PIN housing with male PINS.
    What i did so far:
    I connected the (A) wiring to the (B) wiring via the corresponding black to black connectors, and grey to grey connectors. This left me with the one smaller black connector free as i dont know where that goes. Also, there is a lone grey wire attached to the long 16"length of bundled wires.
    I dont see how this wiring setup plugs into the back of the Depo's? Do i attach this by pressing the crimp ends into the PIN housing on the back of the Depos per appropriate function? WHere does the grey tap into? And what do i do with the black PIN connector housing to connect it into the stock wiring harness as its totally different??? Confused
    Is it as simple as just unplugging the stock bulbs and connecting the grey and black plugs to the Depo 16"harness and then the harness crimp ends to the back of the Depo Headlamps??
    wow, what do I do
    Sorry about that, a cd should have been in there.
    1) Take the pig tail out of the back and put that pig tail into the existing 900X wires from the car (that used to be plugged into your 9006 9005 bulbs on the stock lights).
    2) There is a single remaining wire (for the DDE), that plugs into the parking lights.
    3) If you have a wiring harness, do not do step 2.
    4) If you have a wiring harness, it has a yellow wire, black wire (with blue crimped connector), and a spade connector. Yellow goes to your positive terminal (by your passenger firewall), black goes to ground, then spade is what connects to a blue -ttap- that you connect to either your fogs or your parking light.
    In each case, you connect to the wire NEXT TO THE BROWN ground.
      Right. Whatever you do, don't cut the red wire!!!
        I must have the long harness and the two other harnesses with grey wire, then 2 other harnesses i still dont know which to use. I posted some pics here...
        http://www.picturetrail.com/4tuneit1
        http://www.picturetrail.com/gallery/view?p=999&gid=4131366&uid=2125374
        Could you upload these pics pointing out where the connections go and which harness i should use??
        Ideally i would like the angel eyes to come on with the key turned off and removed for 10 seconds...so i guess i have to use the long harness?
          Bump for help? Check links plz? thanks
            when you ask to use the harness or not, don't.
            see step 4 above for your first picture.
            second picture is what attaches to the back of the headlight - go to our site, look up PnP Lite, and use the wiring information we provide there.
