225 will they fit?
    225 will they fit?
    Ok so i am in a hard spot and i need some tires and my friend has some 225 will that run on my stock 17"s or will i need to get maybe a 235?
    eh overhere standard on the rims is 235/40R17 so 225 sould not be a problem
      ok sweet. damn to short thingy.
        Stock rear rims for the M3 are 245/40's, stock front is 225/45. Remember, the rears are wider than the fronts....
          i have a 95 so all the wheels are the same size all the way around. but will it still work then?
            i think it would fit cause i heard that BMW rims aren't that wide for the tire sizes they have, but i would hold off for the 235's. Unless you are getting them dirt cheap, i would wait. You could just buy some cheaper tires in a 235 and that would probably be better off then going to smaller width tires.
              a little off topic, but i am getting some 18x8.5s all around with 225/40/18..some friends say that these tires will be too small and stretch a little, is this true, if so, i need some advice with different sizes.. note: my car is lowered some.
                I belive my rims are either 8.5 or 9 width, and I run 225 on them heh. I can't remember though :P
                  The listed size for any given tire is only a rough guide as to fitment. Two 225/40/18 tires from two manufacturers, or even between two models from the same manufacturer, may not actually be the same diameter nor the same tread width. If you go to tirerack.com you can check the actual dimensions for any given tire that they sell, eg a 225/40/18 S-03 has exactly the same tread width as a 235/40/17 AVS Sport.
                    i have 8.5 J 18" as well and on the front 225/40R18 andt they are stretch a little 255/35R18 on the rear is looking much better (i it not much stretcht :clap: but just a littel but i think 225 looks better on 8J
                    maby next time i will put 235/40R18 on the front
                      what kind of tires? I had a set of Pirelli suspersports on an 18x8.5 and those were stretched a bit. I have replaced them with S03s - and those look like they belong on an 8.5 wide rim. both sets were 225/40/18.
