add me to the list. Rear brushings out blah.
    I knew it was coming just didnt want it so soon. My rear brushings are out. I realized my car was slipping side ways and on the LIE as i was going about 65-70 the rear went wide left at that point i decided its time to get htem done.
    My mechanic said its going to cost about 950 - 1000 or so. Is this a good price for the amount of work needed ? At this rate mods are never going to come. lol
    How many miles on your car? Also, would this kind of work be covered by an extended warranty?
      i've got about 94 thousand miles on my car. I'm not sure if it is covered but i dont think it is since a lot people here have had those brushings done and i never heard about it being covered. Seems like a wear and tear thing.
        is he talking about the rtabs? subframe bushings?
        If you feel like the rear end is trying to steer, then its probably the rtabs. Those are under $100 for the pair. And should only cost $300 to fix. You can DIY the rtabs, the only hard part is they need to be pressed into the trailing arm.
          950 - 1000 is ridiculous. The parts are about $40 for a pair; labor should be a few hours.
          Go to Motor Works West in Wyckoff, NJ (Bergen county). Shouldn't be more than $300.
            hmm...thanks for the referrel ill have to check them out.
            Ok yeah i just got back and they had my car lifted and basically explained to me what was wrong and if i still wanted to do it that they'd order parts on monday. But i'll probably try and save the 600 dollars.
            When they lifted my car they pointed out this plastic bushing on both sides of my rear that is worn and no longer holding my wheel straight. He took a pole and was able to move my tires side to side. Thats a symptom of the rtabs right ? he didn't use the word rtabs.
            Also he said the parts are cheap, labor is much work because they have to out a lot of stuff. Also that i should probably do a 4 wheel alignment. I've been going to this guy a few times and he was always cheaper than others whiel doing the same job. i'll give motor works a call.
              Motor Works West does fantastic work. Ask for Dave Bogert when you call. He's the owner and is a great guy; extremely knowledgeable.
                ....But bring your lube and grab your ankles. Good work but hella expensive. However there really isnt anyone else in the area that I trust with my car for maintenance.
                -Richard
