My wheel recommendation (and the ones I bought for my car) are BBS RK 17x8 running a balanced 235/40 tire all around (16 pounds per wheel). Plus the wheels are lighter (than the same wheel in 18s), the wheels are cheaper (than the same wheel in 18s) the tires are cheaper than 18s also.Most of the BMW CCA E36 M3 club racers I know, run 9 x 17, 45-mm offset SSR Comps with 245/40-17 Hoosier R3S03s (R3S04s now), all around. Comps weigh 15.5-16 lbs each.
From the reading I've done on this forum, perhaps 9 x 17, 42-mm offset BBS RG-R with 245/40-17 road tires (all around) would be a hot setup for stock suspensioned E36 M3s for spirited roadwork? RG-R, 9 x 17, 42 ET weighs 17.5 lbs each. That has to be lighter than the stock M double spoke 8.5 x 17, 41-mm offset rear?
