which pulley kit to buy?
    I've been trying to find out out which pulley kit would be the best. I have been looking at the evosport Pulley kit and looks pretty good. I could use some input though. Thanks :thumbsup:
    do you have a ltw flywheel? Are you planning on running one? If not take a look at URI and ERT pulleys, much more power for less.
      No I dont have a ltw flywheel. I will look into the URI and ERT pulleys. Thanks for the input. eace:
        I have a set of unorthodox racing power pullies... are thoes the URI's you're talking about? But I took them off cause the belt fubared, but I miss the revs, so I may put them back on. Anyknow the belt size off hand?
        I think they are the older versions though, I wouldnt' mind putting them back on actually.
        Edit: Found the instructions online, Ill look up the part number tonight.
        What are your thoughts on these pullies?
          the URI pulleys are great, the crank pulley is where all the gains are. I'd put it back on.
            You've been running them for awhile right? No seen adverse affects to the engine?
            Happen to have a belt size?
              i have an ERT, basically the samething. I have like 20k miles on it, with tons of track time. No issues.
                Ahh. Sweet. Yeah, I felt a difference when I put stock pullies back on heh.
