rear pulling
    rear pulling
    i just fixed my right rear wheel/bent suspension, alignment new tires, etc. when i accelerate i can feel the rear wheels or wheel start to pull towards the left. does any one have any ideas when im not on the gas it doesnt pull at all almost, it does slightly but its at random times at least i think it is. is my alignment not done correctly or is something loose. when i hit the curb did it mess up a bushing or anything
    any help is needed thanks
    Could be the rear trailing arm bushings (RTABs).
    When my car's RTABs went, the car felt like it had rear-wheel steering under hard acceleration and the rear would tramline.
      HEY! The exact same thing happened with me. I just bought brand new Pilot Sport A/s's and the minute I hit the highway AFTER an alignment, the car would pull right when I hit the gas. It freaked me out.
      That went away after 1k miles or so. Very weird feeling though.
      Are you tires new?
        Maybe the cars just following the crown of the road.
          I had pulling when my rear bushings went out, and when the tires were not aligned or blanced right ( still have to do this )
          And now that my rear shocks just went out on my right i've got pulling as well. Car is in the shop for that as well now.
            Right on the money it was my right rtab along with one of the three bolts being half torn out of the FRAME which holds the (trailing arm, i think thats what its called ). This was a very time costly lesson learned.
              can u visually tell that the rtabs are going bad or only feel?
                you can tell, but you will have to drop the carrier they are in and remove it to see the bushings.
