Need to know if this will fit anyone please asap
    Wheels are 17"x8.5" Offset 44 (Front) and 17”x9.5” Offset 15 (Rear) with 5x120 bolt pattern.
    Tires are BRAND NEW Dunlop SP9000: 245/45/17 (Front) and 275/40/17 (Rear).
    will this fit my lowered m3?
    Im not positive but IM going to say there is almost no way. I have never heard of anyone running 275s on an e36 nor an offset so low as 15.
    Im sure someone can give you a better idea but im almost certain that wont work.
    -Richard
      I don't think 275 will fit.
      I am only running 225's on mine, and almost rubbing on the quarters.
      I don't know what my rims offset is though, and I am too lazy to measure and figure it out.
        The fronts MAY fit. The rears you don't have a chance in heaven or hell sorry.
          Fronts will fit, rears will rub and stick out.
            You gotta roll your fenders for the rears...like everyone said. Sorry man.
              Even rolling the fenders might not fit. Going from- for example- 225/40/17 in the rear to 275/40/17 the tire will stick out apprx. 55mm. And than adding in the 15mm offset, no way.
                Actually...you're right. I just read 275 and thought you might be able to pull it off because I know people have run E46 rears before. Ok, if you cut off your fenders...it might fit.
                  275's on a 9.5 inch rear will fit in the rear, just not with that offset. It needs to be around 44mm for it to fit not 15mm.
