Which headlights are better, Bosch or zkw? :hmm: Both are projectors and should have similar output but I'm not sure. I know that Bosch & Hella are original equipment for the e36 while zkw is an oem product (not original equipment). Does that mean anything in terms of quality? Which one would you choose?
bosch vs zkw
ZKW and Hella are OEM. I don't think Bosch is...:hmm:
I think ZKW's are the only ones with the light pattern that ticks up.
From my research on Ebay Germany, most of the OE (used) headlights for sale are Bosch or ZKW. The fact that my Bosch have vertical adjusting stepmotors also leads me to believe they are OE, as I doubt the aftermarket would bother with this.
BOSCH are most certainly BMW factory, I have them in my car and they have a BMW part number.
They're only available on the Euros with horizon adjustment (or "vertical adjusting stepmotors" which sounds pretty flash). This basically allows you to adjust the height of the focal point of the beam from inside the car.
If you have a US M3 and use the BOSCH units you'll end up with gear you don't need or can't use, hence the recommendation for ZKW as an upgrade to the US lamps I believe.
The BOSCH units have "tick ups" just like the ZKW's and, for that matter, so do all Euro lights.
As for quality, I have no idea as I've never compared them. Suffice to say, I'm completely happy with my BOSCH units.
