Manual Trans. Fluid Change Help!!
    hello everyone:
    95 /// M3 Cosmos black
    I have a Question: is it the same as Auto. Trans. fluid change to do an oil change on a manual?! I couldn't find any DIY sites on Manual Trans. fluid change.. anyone has a tip! any brand?
    Also, I noticed that the clutch has gotten harder to eng. in as it was before, any idea on why?? ( no , the clutch is not slipping ).
    Thanks in advance
    Sam
    It uses ATF fluid.
      It's a bit easier than an auto.
      Heres the DIY link for changing manual tranny fluid. (http://www.unofficialbmw.com/e36/drivetrain/e36_change_manual_transmission_fluid.html)
      I think most guys here will recommend the Redline D4ATF. I'm actually planning to do this soon to my car also, plus with some Redline 75w-90 in the differential.
      Heres the link to changing diff. fluid....just in case. (http://www.unofficialbmw.com/e36/drivetrain/e36_final_drive_fluid_change.html)
        I'll use the stuff at work until I leave... I get it free...
          thanks a lot for the info guys.. your input is great!!
          good site as well on DIY.
            LOL...and the bragging continues.
