*differential bolt problems** again
    Hey guys...a few months ago, i was getting a knocking coming from underneath the rear end of my car. Realized that my front differential bolt had worked just a bit loose. So, i tightened it up and didnt really give it much thought (althought it was probably bent at that time and i didnt realize it.) Then, a couple weeks later it snapped in half and the bolt needed to be drilled out. I took it to a guy who removed it and put a 1/2 inch hardened steel through bolt in. In only one week of time, the new bolt has begun to work loose already. Where is this torque load coming from that causes this?
    How can i fix this? Anyone on here have the AA DSB? or any other type of differential support bracket? I remember seeing an add for a sale on the DSB and X-brace...anyone know of that price?
    any help would be appreciated.
    Thanks,
    jeff
    http://www.aatuning.com/specials/DSB-xbrace-special.cfm
    i told you about this on your last post man! come one now get with it, just buy the piece and save yourself from this problem
    it comes from hard shifting mostly from 1st to 2nd, the website gives you a professional explination, check it out
    since your kinda close, i could give you a hand if you needed, im in harford co, MD which is like 20-30 min from lancaster
