radiator problems!
    radiator problems!
    So my M is giving me lots of problems. Just a week ago I had the power steering hose fixed and today while driving i heard some kind of equipment from my car parting with me. An hour later all my coolant was out and car thermostat indicated HOT. I was going to get the inspection done next week but dont think it's worth it now. Any ideas on problem? I am going to try to add radiator sealent tomorrow, we'll see...
    usually the leak is where the hose meets the radiator on the top right. Sometimes if you tighten down the booting to tight the plastic will crack and it will leak. Ive heard you can get a black light out and you can look for the fluid...
      wow that sucks. you think this will cost a good amount? usually everything does with these
        Luckily I got my radiator under warranty let me check my invoice see how much they charge. But hopefully you can find a leak and not a cracked radiator.
          These radiators like to seperate from themselves, usually at the top where the metal part meets with the plastic. The only choice you have there is to replace it.
            You can probaby get a radiator and hoses for >$200. Get a buddy or two to give you a hand and you can replace it in a couple of hours. Get 2 bottles of BMW coolant and 2 bottles of DISTILLED water. Make your you bleed everything properly and watch your face if you draint the coolant from the block because it goes everywhere.
