How much does the factory flywheel weigh?
    Hey ya'll...I just wanted to know how much the factory flywheel weighs on the E36. Reason for asking is because I'm planning on swapping it out with a lighter one and wanted to know the difference. Thanks!
    24lb.
      24lb.
      I thought the 95 was 29lbs and the 96+ were 22lbs...I am pretty sure there is a 7lb difference between the years.
      -Richard
        29 lbs is heavier than any other stats that i've seen from all the aftermarket parts websites. it's around 23-25 lbs for the stock flywheel.
          short answer = too heavy
            Listed at 27 pounds by Rogue Engineering.
            http://www.rogueengineering.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=LTW
            I know for sure there is a substantial weight difference between the obd1 and obd2 cars.
            -Richard
              they have the spare listed as 50 lbs. mine only weighed 40. that is a good list, but it should be used as a reference point only.
                It is probably a list for 96+ only as the spare is a contour which weighs more than the stock 95 wheels. Youre right the list might not be 100% accurate but I am pretty sure the flywheel weighs more than you think.
                -Richard
                  -Richard
                  no a stock contour weighs within a lb.or 2 of a double spoke 1. no way there is 10lb difference.
                  when i shipped my dual mass fly, cluch, PP, throwout bearing the total weight of the package was 38lbs.
                    yeah, i started that post thinking the spare would be a contour (2lbs) and possibly 8.5" wide as the 96+ rear wheels are (maybe add 2 pounds for that and a bit more for the 245 rubber)
                    Then I realized that the spare would be a 7.5" and I am not sure why there would be a 10 pound discrepancy between the Posers wheels and that listed on the Rogue site.
                    -Richard
