Vanos Solenoid done... WOW, what a difference
    hey guys,
    I suspected that my vanos was dead or not working properly for quite sometime, i just didn't have that low end torque that i felt like i should. I dynoed my car and got 230HP but only 200tq so i knew i was lacking in powe b/c i haven't seen a HP tq gap that big on a E36 M3. so I figured it was either mechanical or the solenoid. You would think that a bad solenoid would throw a check engine, but it reality it rarely does. So i bought the part for about $115 and put it in. install was rediculously easy, took about 15min. all you need is a 32mm wrence and a few towels to clean up any oil that drips. its directly to the left of the oil filter housing.
    Anyways, after i finally pulled out and drove it around for a while. I could not believe it. it felt like a whole new car. Idle definately sounded much better and sputtered alot less, exhaust sound changed to a much healthier tone, and car just has torque everywhere now. Idle is still alittle rough on cold starts but thats probably b/c ICV is really dirty (never been cleaned). The torque is so much more abundant. WHen i dynoed my car last week the torque band looked great b/c i had flat steady torque all the way from about 4300-5500 rpm but below that there was just no torque whatsoever. yes during accel its much more torquey and the top end even felt better making me think that vanos was stuck somewhere in the middle, but the best enhancement was just regular daily driving. now i dont have to rev the car nearly as much to get it going. i start feeling torque as soon as 1500rpm where as before i wouldn't really feel anything till about 2500. cruising in 3rd and 4th much easier now and it pulls alot more in daily driving situations. It made it much more plearsurable to drive on a daily basis. MId range torque is phenominal now. can't wait to redyno.
    Moral of the story, even though there was no visible sign of any kind that would make me think it was bad, i still had a hunch and wanted to try and solve the problem so i changed that first instead of spending $500+ for new vanos and etc. Over time they just naturally fatigue and don't work like they are supposed to. So if you are having problems first and still don't think its solenoid you might as well replace it first just to be sure. I'm very happy I did. I will try and get redyno soon to see how much it helped out exactly. anyways just thought i'd share that.
    very interesting, how many miles on your car?
      ICV??? whats that?
      Where is the solenoid and what does it do?? Is it worth checking?
        ICV??? whats that?
        ICV = Idle Control Valve
          Supabimma, If I feel any issues with my VANOS, Im coming to you! :thumbsup:
            How about a DIY....
              Where did you get your solenoid from? Stealership?
                you can get them anywhere, it was $115. yes very DIY, about 5 min tops, its so easy its not even worth a writeup lol
                  does anyone know how to clean IVC?? cause it feel werid when the cold start my car..anywayz so as for the Solenoid..all u need is a 32mm socket to do the job?? cause i brought Solenoid from dealership and just wondering how easy or DIY would it be if i want to do it 2day..and also wat should i watch out for..well let me know and thanks.. :wave: :beer:
                    i never saw this thread for some reason.. although im glad i did now.. i might have to check this out at some point... yeah how bout a DIY on it.. that would be nice to have on the forum... and definitly when u get a chance.. post the before and after dyno.. i wonder how often it should be replaced.. maybe its one of those parts that should go under the standard maint. number..
                      Mine has torque issues ,pulls when it wants ! could this be my problem ? :nixweiss:
                        My car is having the same issues. I have tried fixing everything to no avail and this is my last thing that it can be, and looking at it, I am pretty sure this is the problem.
                        when you did yours did you just replace the solenoid switch, the $115 part #11361703720 , or did you need to get the piston (part # 11361738495 ) and the O-Ring as well (part # 11361703713 ) ?
                        Thanks
                        Eric
                          how many miles does ur car have eric? just trying to put in perspective how soon this should be done to ensure i keep full power.. well i think i have full power now..
                            The engine has about 23k on it.
                            I noticed it because I was getting very weird results on the dyno. A very bad dip around 5k rpms in power that looked like VANOS should do its thing, but instead I just loss power and then its spraying oil in my engine bay.
                              huh?? how come the solenoid is cost $115?? my i brought it from the dealership and is only cost like $86 without tax..and with tax is like $99..did i brought the wrong unit?? or all the dealer had different price?? well does anyone wanna do a write up for this DIY?? casue i kindna need it to find where is the solenoid located.. :nixweiss: anywayz let me know and thanks.. :wave: :beer:
