Installed the M50 manifold on my 328i M
    Oke so I installed the M50 manifold on my 328i M.
    Now here we go.
    When I started the car for the first time it turned of immediatly.
    Second time it runs realy bad so I think I let it run for a while.
    But it stays running bad at Idle.
    After a couple of mins I took the car for a spin. When Accelerating the car is doing a great job now but with a constant speed at low RPM's the car is shaking and the idle problem is still there....
    I can feel the improvement of power under acceleration in every gear.
    But I can't get the Idle good and the problem from cruising at low RPM'
    s
    Can someone help me out here???
    sounds like an intake vacuum leak. check the hoses.
    btw - what is a 328i M ?
      Second the motion about the vacuum leak and what is a 328i M?
        Hehe it has full Mpackage everything.
        Head is flowed too.
        Btw if it is a leak it should run bad under accelerating too right but is doesn't.
        When I hit the pedal it is accelerating like crazy. 0-60mph increase by almost 7th of a second and from 0-top end increased even better
        So I don't think it is a vacuüm leak or anything??
        Could it be the learn process??
          m everything with a 2.8 huh?
            Yeah sumth like that.
            US m3 spec but then a euro 328i
              Why??
                Do say it isn't an intake leak until you check and double check....it sounds exactly like and intake leak. After that...check the idle control valve and hoses.
                  I don't get it. how is it a US spec M3 if it is a 328i ?
                  :nixweiss:
                    its a 328 with a body kit.
