Replacement Battery?
    I went to start my car after letting it sit for 4 days and all I heard was the silenoid clicking and then a metallic woodpecker noise which I can only assume was my starter not getting enough juice to actually spin up. After sitting in the cold for last 4 days and having me leave the cabin lights on for 30 minutes without the engine running, I wouldn't have imagined that my battery would drain enough not to start, so it must be bad. Do you agree?
    Also, if you were to get a replacement battery, what would you get? I want something with OEM fitment and equal power and reliability. I've heard some dropping in Optimas (which I have in my truck and boat), but does this fit the same and is there any benefit (my car doesn't get bounced around a lot and it doesn't sit for more than 3-4 days at the most)? If my battery is original (I'm checking with the previous owner), I almost think that I might just get another BMW battery since 8 years is pretty good.
    TIA,
    F
    TIA,
    F
    Optima batteries are awesome. Lots of CCA's, and plenty of juice for the job. If your battery is original, you might want to replace it. Usually a battery won't discharge in just 4 days, either you just have an old battery with old electrolytes which won't hold a charge, or you have a weak alternator which doesn't charge the battery enough. First thing I'd try would be replace the battery with an optima, and if this happens again, investigate the alternator. good luck!
      i second optima........ sealed batteries are the way to go
        interstate battery
          Had the same battery problem three weeks ago. No one at either of the two Auto-Zones I went to had a clue so I ended up with an OEM battery. $140 - OUCH!! I was able bargain the club price, but still $100 bucks.
            interstate battery
            this is what i got.. its about 2 inches shorter and definitly saves weight.. its a must do :beer:
                For those of you who have Optimas, which one fits a '99 M3? I went to the site and plugged in my ride, and it says they don't have one that fits this car. Thx.
                  I have 2 Optimas already in other vehicles and they work great. Does the standard red top fit in the M3 without any problems? Do the tie downs work ok?
                  F
                    F
                    i'm not sure about which model & color top fit our M's...... i've still been trying to find out with no luck :banghead:
                      The one in my car was replaced with an OEM battery from the dealer. I remeber it was around $120 with me installing it myself of course.
