Rear Deck Rattle Fix! (E36 M3)
    Before I post this, I can not take credit for this easy fix.
    Like many of you, I have looked at different options on fixing
    this very annoying rattle usually located in the rear deck area.
    I was actually going to tear apart the rear deck this weekend
    and dynomate the entire sheet metal area this weekend in
    an attempt to fix the problem once and for all.
    Anyways... yesturday, I read a post by another member who
    stuffed pillow cotton into the holes found in the trunk that
    lead up to the rear deck and speaker area. I went to Wal-Mart
    and browsed their Linen area and found pillow filler which costed
    about $1.85 for a huge roll. I began to stuff this filler into the
    5 main holes found through the trunk. I concentrated alot of
    filler on the center hole and the remaining filler was stuffed
    near both speakers. Overall time, 10 minutes at the most!
    I took my vehicle out at about 10:00PM with the temp at
    about 35 degrees. No rattle. My MD player was off so I could
    listen carefully. I then turned on my MD player and faded
    all the sound to the rear and had my bass on +10, no rattle.
    On my way to work this morning, the temp was around 25
    degrees. Most of you guys know that at this temp, the rattle
    is out of control. With the music off for about 10 minutes of
    the drive, no rattle is to be found! At first I was very pessimistic
    about this easy fix, but I'm sold. The pillow filler expands
    between the sheet metal and rear deck causing any loose rattles
    to go away. Try it out.
    Now for the real problem, suspension overall in the next month!
    very good tip. i'm gonna have to try it. that rattle is pissing me off!
    -mike
      Same here, mine didn't start till this morning. Grrrrrrrrrrrrr
        im gonna try it too,thanks for the tip.the rattle makes me want to shoot the subs in the back.
          My package tray vibrates a bit around one of the speakers when certain frequencies of bass hit... I'll have to try this fix.
            and this has helped in isolating the package shelf from the metal of the car.
            Marc
            95M3
            LA
              ha, i'm gonna do this also... my gf keeps telling me the rattle is annoying... i just zone it out... i think i'm going to tear apart one of her fav. pillows to try this fix :-)
                Ummm,good idea,im gonna snatch one of my wife's 40 throw pillow in 3 bdm to do this set up....shell never notice... :thumbsup:
                  UPDATE!
                  I had a chance to glance at the pillow filler I used yesturday, I think it is made up of some type of polyester material. Polyester is alot more elastic causing it not to fall apart into little pieces. I hope that made sense.
                  Anyways ... On the ride home from work, temperture was right about 29 degress. Again, driving pretty slow and over alot of bumpy surfaces ... the rattle is complete gone! Music sound so much better when you do not have to deal with all that rattling!
                    UPDATE!
                    did you crank the music up to the max? and it sound good?because i have 2 12" JL--W3 and a 800w lanzar amp,i would love to crank it up but the rattles just kills the music thats why most of the time i leave my window open a crack.
                      Thanks for the post. I am definitely going to try it.
                        //m328is
                        I cranked up my volume 3/4's way. This is usually where the bass causes the rattling to occur, especially on cold days. Anyway, the rattle is gone. I honestly do not know how long this fix will last, but I'm feeling pretty confident.
                          //m328is
                          i have faith in your words,,im gonna try it bud. :thumbsup:
                            yeah me too. i just posted a question about this not long ago. Thanks for the update...I will try it this weekend after I put my Axxis Ultimates on!
                              wow!.... that idea seems uncanningly familiar
