i've searched these forums for more info on solid lifters and while they do seem to be something you would mainly consider for FI cars I see a major price discrepency from the two main places I have seen the solid lifter kits, VAC motorsports and Schrick(through TMS)
Why is the kit about $1100 from VAC and the schrick kit from TMS about $280? What makes up the $820 difference?
And does anyone know what they mean on the TMS page about the kit requiring machining of the shims to set valve lash?
So here are the links to the respective sites.
VAC motorsports solid lifter conversion kit:
http://vacmotorsports.com/cgi-bin/view_item.pl?item_id=9
Schrick solid lifter conversion kit from TMS:
http://www.turnermotorsport.com/html/detail.asp?PRODUCT_ID=086311700
Any help from anybody who knows about these please help. Thanks in advance.
I dont know about pros and cons to hydraulic vs. solid but at from what I've been reading(paraphrased from the TMS description) at high RPM the valves float and Hydraulic lifters keep the valve open because they think it is valve lash. Piston come ups and then you can get bent valves.
Basically it looks like upgraded valve springs and solid lifters may help to prevent valve float in a high HP/RPM situation or a mis-shift. Example would be that at 9000 RPM(not that our cars get that high) a hydraulic lifter wont be able to keep up where a solid lifter would. Again it looks like the solid lifter conversion is mainly for FI cars with lots of HP/trq that regularly see high RPM's.
This is what I've found in the research I've been doing so if anyone knows better please correct me where I am wrong.
Check the second dyno graph here and you can see the torque/HP line effected by valve float
http://www.dtmpower.net/forum/showthread.php?t=142180&highlight=valve+float
Anyways, the question still remains. Why the $800 difference?
