Junk in the trunk :)
    During "spirited" driving and taking turns my rear end feels super loose. I will be replacing the stock shocks soon with Bilstein sports most likely. Is there anything else that I should do or replace to fix this problem? I know the x-brace and strut tower bar tighten the front up but I would like to tighten the rear without having to have a big bar take up my trunk space.
    replace your rtab's and put in shims.
      That and while you're in there, put in E46 RSM's with Z3 reenforcement plates.
        Yep, was planning on doing that. Sounds like new stock bushings with GC shims are the way to go too. How long are the stock rtabs supposed to last?
          My originals were cracked at around 120,000. Most people suggest you replace them ever 80k or so.
