Shacking!!??
    Shacking!!??
    Latley when I start up my m its very shacky for 4-5 sec then it smooths out.. And every couple minutes when im driveing it will start to shack for a couple seconds then smooth out!! :banghead: feels like the engine is shacking out of balance?? im an idiot any idea's?? :bow:
    Come on Trevor I know your on here lol :thumbsup:
    checked oil level? maybe a bad motor mount?
      oil is fine.. a motor mount could cause that?
        Can you get any readings pulled from the DME? There might be some faults stored. I would check for small vacuum leaks in the engine bay.
        A bad motormount leaks fluid. A broken engine bracket creates a constant vibration, as does broken tranny mounts and brackets.
          Sorry could not resist....Shacking? shack shacked shacking shacker
          shake shook shaking shaker
          sounds like a problem with the ecu
