So I put on drilled rotors by zimmerman all around. Also did a drop with tein shocks. Now my car shakes like a mofo at 50 and above. Slowing down is intense shaking. I'm sure all the rotors are on correctly. When I stop too, I hear grinding in the front. Coud it be that I did not get an alignment after I dropped it? Where should I start? Thanks
Car Shaking after spring & rotors
Get an alignment. Also check all your wheel bolts.
sounds to me like you may have either a lazy caliper or bad pads. the shaking can be caused by a lazy caliper, or wheel balance or a bent wheel. If you hear grinding when on the brakes, and intense shaking then you have a problem with the rotors/ pads, or check that little spring clip that holds in the pads. alignment will not case those problems.
