Cant get rear caliper piston to depress!! Need HELP!!
    Should the brake line be capped if removing the caliper for a period of time? Will the brake fluid continue to flow?
      Yes cap it but it doesnt really matter, whole system should be flushed with new fluid
        Yes but if enough fluid leaks down, won't this allow air to enter the system especially within the ASC system which is a bittchh to get all the trapped air out of.
          Its definately better to cap them, I used platic tees last time. Your right in that it is preferable not to let any air in from up top!!
