Did you check the part numbers to see if theyd match? Did you call Unorthodox with these questions?
Underdrive pulleys, What manufacturer?
hey guys. to bring this thread back to life.
I started a separate thread regarding an unorthodox crank pulley I bought. it is an obd1 pulley going on an obd2 car. will it work?
when I tried to swap the pulleys I noticed the bolts for the stock pulley are larger, and the pulley which connects to the ac belt is smaller.
I was under the impression that the ac is not affected by the ur pulley.
help
Only difference between OBDI and OBDII crank pulley is the OBDI has the 60/2 toothed wheel on the outside of the motor, where as OBDII's is inside the crank case.
