Winter is here and I've noticed last winter on a bunch of forums this type of thread pops up at least once a week on pretty much all engine specific forums.
During the winter, it gets so cold that the oil vapors in your crankcase and condensates onto your oil cap. Most people see this when they go to change their oil or just take of the cap and panic thinking. It's nothing more than oil/water emulsion.
What it is:
What you are seeing is nothing more but oil sludge. It is the result of hot oil fumes condensing at the oil breather area near the oil cap and interacting with moisture from the air, mostly in cold weather.. The white-yellowish goo you see is oil condensation mixed with water vapors.
What causes it:
This yellow sludge, goo gunk, whatever you wanna call it, formes because:
1. You drove the engine frequently on short trips and it could not heat up long enough to burn off the water vapors.
2. The oil seals on the oil breather and the oil cap are shot (rarely).
3. You did not tighen the oil cap all the way
4. It's cold outside
How to fix/avoid this:
1. Replace both oil gaskets in the oil breather. One sits between the oil breather and the valve cover. The second gasket you must replace is the one on the oil cap. When these gaskets get heated, the rubber/silicone often burns and shrinks thus allowing for moist air to enter and interact with oil fumes
2. Avoid short trips
3. Switch to synthetic oil. Synthetics have better detergent qualities and will not sludge as much as the conventional motor oil
Hope this makes sense and
cliffnotes:
Milky residue is to be expected on your oil cap in cold weather. It is normal and NO FIX IS NEEDED because it is NOT a problem.
go on and be smart and safe
http://img.photobucket.com/albums/v235/Ollie18/DSC04578.jpg
http://img.photobucket.com/albums/v235/Ollie18/DSC04577.jpg
http://forums.justcommodores.com.au/attachments/vr-vs-holden-commodore-1993-1997/50932d1219471384-stuff-my-engine-oil-cap-please-help-image080.jpg
http://dubpix.com/Pics/VORTEX/PIC00434.jpg
http://forums.pelicanparts.com/uploads7/IMG_25511144676344.jpg
now with some great words
If the women don't find you handsome, they should at least find you handy.
http://media.firevortex.net/icons/custom/standard/thumb_up.png http://media.firevortex.net/icons/custom/standard/thumb_up.png http://media.firevortex.net/icons/custom/standard/thumb_up.png
http://i600.photobucket.com/albums/tt83/ninety9gl/milkbags3.jpg
What it is:
What causes it:
cliffnotes:
