Since it’s been pretty slow around here I decided to start a thread for my most recent project; another rear suspension overhaul. Less than two years ago Calvin and I refreshed the rear suspension in a single night by dropping everything down, pressing in all new bushings/balljoints, and then reassembling it. However, since we were restricted by time, I wasn’t able to fully finish everything I wanted to, and a few things were left out. Not to mention the addition of some aftermarket parts that I later found caused some new issues that had to be addressed, such as the Powerflex subframe bushings which need beefier washers and the SPC LCA’s that need spacers to keep the bushings centered. With the acquisition of a new diff, and having the car down for the winter, I figured this was the perfect time to finally finish what I started.
The purpose of this thread is not a DIY or anything, but rather a documentary of my progress as I undertake this project. If anyone has any questions on anything about this or needs part numbers, feel free to post up in this thread and I’ll gladly share any info as I’ve got a good amount of research into all the necessary part numbers etc etc. Here’s what I’m going to be doing this time around:
Weld in AKG Sway Bar Reinforcements
Box in diff mounts on the subframe
Install new repacked *** wheel bearings courtesy of Bear Motorsports
Install rebuilt half shafts courtesy of Bear Motorsports
Install 3.38 diff with brand new clutch packs
Weld Mike Radowski Diff Support to the new 3.38 diff
Install AKG front diff bushing
Replace steel SPC lower control arms with SPC Aluminum LCA’s
Replace Powerflex subframe washers with beefier McMaster Components and E92 Bolts
Replace all bushings and balljoints again, as well as all new hardware (including new dust shields, ebrake cables, endlinks, bolts, etc)
Media blast all suspension components and powdercoat
Joe came over last weekend and helped me get started. We pulled the entire rear suspension as a single unit and from having the wheels on the car to having the rear suspension disconnected and on the ground, it took us less than an hour and a half. This method in my opinion is much easier than trying to unbolt everything while it’s still on the car, and disassembly was a breeze with a lot more room to work with. Since Joe had just tackled this job on his car, he was a huge help in directing on what gets disconnected first and showing some tricks to the trade. All in all, it was not as difficult as I was expecting. Also, for what it’s worth, the axle nut in the rear is a 36mm, not a 30mm, as it took us two separate trips to Sears to figure this out :facepalm: :rofl3: Here are some pictures of the current progress:
http://i635.photobucket.com/albums/uu76/bdbello/P1090039.jpg
http://i635.photobucket.com/albums/uu76/bdbello/P1090041.jpg
http://i635.photobucket.com/albums/uu76/bdbello/P1090045.jpg
http://i635.photobucket.com/albums/uu76/bdbello/P1090046.jpg
And my newest editions to the garage, which made this job a whole lot easier!
http://i635.photobucket.com/albums/uu76/bdbello/P1090047.jpg
Calvin currently has my half shafts, wheel bearings, diff, and some other parts, and is rebuilding them all for me. Joe has my subframe and put it through the tumbler at his body shop. Ant has my RTA's, upper control arms, and all other parts that will be stripped down and powdercoated. I just wanted to give a big thanks to these guys, who without this project wouldn't be feasible. I'll try to update this thread with pictures after any progress is made! :rulaiz:
