Then i took my current car cellphone charger and snapped the cigarette lighter male portion of it open. i noticed there was a spring which went to the button on the tip (power) and then the side prongs are ground. I snipped the spring and button off, the soldered the a stranded wire to that point on the circuit board. Then i cut off the side wing-prong things and soldered a ground wire to it. Then i used wire taps to tap into the OEM cellphone harness located under the cupholders in the center console. Much better than using the cigarette lighter and is clean.
yes.. thats what i was trying to explain above. :thumbsup2:
