DISCLAIMER: Perform this modification at your own risk. I am not responsible for any consequences.
For folks who have deleted their A/C system and would like to convert from belt driven mechanical fan to electrical fan, there is a very simple way to do it:
1. Get a 16" electric cooling fan; i got mine from ebay.
2. Attach the fan to the radiator using the OEM shroud (easiest, and retains factory overflow reservoir)
3. Keep the kep out of the ignition. Cut off the factory AC condenser connector (3-pin).
4. Wire the ground of the AC harness to the ground of your new cooling fan. i used a female blade crimp connector which plugs right into the fan connector
5. To wire up for two speeds, you will need to wire the low speed and high speed AC harness wires according to the following diagram:
http://i109.photobucket.com/albums/n43/mchuffman/M3fanwiring.jpg
Again, i used a female blade crimp connector to parallel the high and low speed wires to the fan positive. you need to use a high wattage resistor or it may get hot and burn up or cause an electrical fire. i used two 50 watt, 1-ohm resistors wired in parallel to get the neccessary power capability.
This setup uses the factory AC fan temperature switch, which will activate on low at 91C and high at 99C for a 96-99 M3.
To test operation, you can jumper the harness side of the temperature switch in the side of the radiator. following a wiring diagram for your year, jumper the low and high terminals to ground. With the ignition "ON", the fan should run in low and high speeds.
There you have it, aftermarket fan is wired up without using relays or additional temperature switches.
ORIGINAL POST:
Hi all,
I'm looking into the electric fan conversion (deleting the belt driven fan). Instead of wiring in new relays, couldn't you just install the lower temperature switch and use the AC condensor fan wiring to power the new fan? (i deleted my AC)
My assumption is that the AC condensor fan kicks in at a certain engine temperature to help with cooling regardless of whther the AC is ON. If this is true, the AC fan wiring could be fed to the replacement electric radiator fan.
ORIGINAL POST:
Hi all,
