Hello everyone, this is my first post so I just wanted to introduce myself.
My name is Steven and I have just bought a Cosmos Black 1997 BMW M3 5-Speed w/ Luxury Package and ~172K miles. I have been searching for an M3 for about a year now, so I do not consider myself a complete noobie, but I'm sure there is a nearly endless amount I could learn through experience and the wonderful community right here.
I've actually bought this one right here:
http://www.m3forum.net/m3forum/showthread.php?t=390767
But after post 50 (or so), I felt like it was turning in to a lot of bickering...So I want to start fresh!
I saw Tony86420's ad on craigslist and ended up purchasing for $4800. I would just like to say that my experience with him was absolutely top-notch and I could not have asked for more.
1. I inspected the vehicle myself, and based upon the 15+ other ones I've looked at in 2011, this one seemed to be in the nicest condition aesthetically and functionally. Especially considering the miles!
2. I called around and found a BMW mechanic to do a pre-purchase-inspection on it for me. He is Hungarian and has been in Arizona since 1979; no punk kid straight out of mechanic school.
Anyway, the car does have a Restored/Salvage title on it, however I don't see that as being too much of an issue. I'm a college student studying engineering and just going to be using it as a daily driver/fixer-upper and no plans to sell. I've changed head gaskets and such before, so I'm pretty comfortable under the hood.
Here is the entire list of what was noticed in the PPI:
-No side mirror adjustment
-Wiper stop immediately when switch turned off, not at bottom of windshield.
-Both inner tail lights out
-Rear passenger dome light out
-Both service lights on
-Drivers window rattle noise (regulator, motor)
-Both belt tensioner shocks worn.
-Power steering supply hose leak
-Check engine light on
-Clutch pedal heavy (pressure plate)
-Both front lower control arm bushings & bracket installed wrong way
-Steering shaft flex disc damage
-Passenger front strut leak
-Front struts not for M3 (possibly for 3-series)
-Rear trailing arm bushing broken
-Wheel alignment (steering off)
-Oil filter housing gasket leaking
-Both engine mounts broken
-Shifter handle bushing worn
-Engine oil low
-Brake fluid dirty
-A/C belt
-Cabin air filter
Bolded items have been specifically marked by the mechanic as unsafe for immediate use. Everything else looked good.
Because the Spring semester has already started, I decided to have the shop address the flex disc, control arm bushing/bracket, and install the correct M3 struts with new mounts. It was an expensive decision, but I need transportation ASAP and there is plenty left for me to work on.
I hope to hear about all your thoughts and comments!
It is currently in the shop, and I was told it will be done by tomorrow afternoon, but I was thinking of calling them and asking to slap on a reinforcement plate while he's working on the struts.
Will post pics when it's home! For now though I will be registering with BMW CCA and buying myself an ugly ///M cap or something!
Cheers
January 17, 2012 Update:
Took the car to a relative to have it put up on the lift and inspected by myself.
New OEM Sachs struts installed by mechanic. Strut mounts were replaced also, I just didnt take a picture:
I changed the oil to Mobile1 synthetic 5W-30. New oil filter and air filter also :-)
In addition, we went to the auto part store to borrow an OBD-II reader, and it pulled two codes.
One was because the car was started when the gas cap was off, and so the sensor detected a fuel leak or something...
The second was code P0430, an emmissions problem in "bank 2" which I have googled and found to be an O2 sensor past the catalytic converter.
So I went ahead and reset/cleared the codes out, and so far so good (2 days later) no check engine.
Originally Posted by :
Replace the rear trailing arm bushings right away so you don't rip the bushing pockets out of the floor pan (Common).
We investigated this, and I was told that a good test (outside of tracking the car or slamming the brakes at 70+MPH) is to shake the wheel to find play in the bushings. I did this to all four wheels and I was not able to get any wheel to budge with all my might.
Also if the motor mounts are 'broken' as the PPI said, I'd replace those ASAP, too.
I was also told, that the mechanic was full of it. I guess when motor mounts are broken, the engine twists and shakes quite a bit on start-up, rev, and engaging clutch. We looked at this and honestly the motor was not moving more than 3-4mm under the worst conditions... So unless anyone can provide insight I think I'm set.
If the clutch pedal is heavy, you're probably going to need a clutch at some point, unless someone has installed an aftermarket clutch with heavier pressure plate springs.
I will have to look into this. Talking to the mechanic after the PPI led me to believe that there was in fact an aftermarket pressure plate installed, but I can't be certain.
-Engine oil low
-Brake fluid dirty
-A/C belt
-Cabin air filter
Cheers
