Factory BMW alarm or others?
    I have a UAS alarm, has worked great since I installed it, completely plug and play, and it's got the modern looking flip key, with a little bmw logo on it, looks completely factory. I can also arm/disarm my car in the parking lot from my 16th floor. I don't agree that the car should be left completely stock because of its low mileage, there is nothing wrong with putting better components on it as long as they're not tacky. Infact, the next thing I'd rip and throw in the trash, are those stock headlights.
    +1. Get the option where it rolls up the windows and closes the sunroof. Its the stuff. Also the one piece keys are excellent.
    Sent from my DROID X2 using Tapatalk
      I have never had one in my possession so can not say other than what I have read. My understanding was that older, non-pre-wired E36’s could make use of the 3-button system (assuming a harness of some type was required) and that in the ~96 MY they began to pre-wire for the 2-button Alpine. I know that the 3-button style was also used on other older models (7's and 5's) but have never personally witnessed it work on an E36, only the newer 2-button Alpine. If you have maybe get with the person and find out what, if anything, they did to make it work.
        European cars didn't get either Alpine alarm, an alarm plug or any pre-wiring. Instead a European customer could optionally order a car with a different alarm system that was installed at the factory. In later years, the control unit was part of the ZKE (central module). The transmitter is also built into the master key. If a customer didn't order and pay for these things, the car got nothing.
        K, but he's in the U.S. and we're discussing the options available here. While I appreciate the information for non-US cars, it's adding information not really needed in this particular thread.
          If you look at the 3-button auction, the plug on the harness is for the pre-wired cars
            K, but he's in the U.S. and we're discussing the options available here. While I appreciate the information for non-US cars, it's adding information not really needed in this particular thread.Except that not infrequently someone outside North America will read a "factory alarm" thread like this one and ask a confusing question or give a confusing answer that has everything to do with the factory alarm and nothing to do with the completely different alarms you guys are talking about.
            The other point goes right to the core of what others have written so far. The BMW/Alpine alarm the OP asks about wasn't original equipment. With a little care, you can find at least comparable alternatives without the BMW roundel, that are arguably as original or aftermarket-ish (if that's a word).
              I was suggesting he choose a part provided by BMW. The Alpine alarm system is a BMW branded and dealer stocked kit that would go wonderful with his low mileage M3.
              The only other system that is ~PnP non-BMW cool, which I have too, is the UAS kit. The only thing that makes this kit unsuitable is that the alarm kit doesn't interface with the pre-wired accessories (alarm siren, LED). Obviously you can get the non-alarm keyless only kit and there's no problem. If security is an issue, I suggest using the OEM Alarm KIT that is 100% plug and Play. If he just wants keyless and automatic window roll-up, get the UAS.
              Viper, Clifford, remote start, pager keyfobs, etc, etc ... sorry, but these are rats nest kits and crap.
                I see. So, there's plug-and-play and there's honest, plug-and-play.
                Have you seen the harnesses and "accessory bag" BMW gives you to add their alarm to a European E36? I suppose technically they make the job plug-and-play, but they would make anyone thankful for the prewiring that went into a U.S. car.
                  @ El Stig - thanks ! That information was extremely helpful - you rock!
                    Yes, all you have to do is erect a straw man or two and watch him blast them to bits. :thumbsup:
                    Thanks for the very helpful review. I've been researching an alarm and your comments resolved what I should do.
                      John, how is the alarm coming? It sound like it will be really unique and have that cool oem factor.
                        It's coming along. I ordered a spare BMW DWA V retrofit kit since it shows as NLA in the ETK. The EBA suggests the kit came out in late 1998. It has a funny mix of things from the E36 and E46 factory-installed alarms.
                        The design and components seem to be of decent quality. The alarm components I received were made in December 2005 by Beta Elettronica, an Italian security electronics firm. They use Molex Mini-Fit Jr. connectors, a not unpopular choice of automotive OEMs and aftermarket companies. I haven't taken things apart because of the warranty seals, but from what I see this wasn't a lowest-cost design.
                        The kit includes a generous helping of BMW/AMP 2.5 mm^2 contacts and single position shells to install it in well nigh any E36 ever made. It will take a little desk work to sort out what bits I will and won't need, and how best to hook everything up.
                        I'll use a modified ASC switch in place of the supplied illuminated alarm switch. OSRAM recently came out with a more efficient surface mount LED that should light up the button a nice, bright blue.
                        I plan to add the original equipment E36 tilt sensor since the retrofit variant is NLA. The ZKE has an output to activate it when you double-lock the car, but the output may stay off if the ZKE isn't coded to act as an alarm controller. I may have to whip up a simple substitute.
                        I'll hook up the alarm to and control it with a two-way remote/pager. A candidate I'm considering is the brain and remote from a Crimestopper SP-501 Alarm / Remote Start System. It should have what I need: arm and disarm outputs for the BMW/Beta alarm, a two-stage unlock to pop the trunk, a remote start output for the auxiliary heater, and a basic accessory button/output for everything else. I'll prune the Crimestopper bits to the bare minimum and hook them up through a generic interface connector in case I ever need to replace it with something else. Alarm models and even companies seem to change with the seasons.
                        Has anyone had experience with Crimestopper? Their tech support seemed pretty helpful.
