Hi
Mine injectors are going dark side, need to change them.
Would like to put new, try to avoid used but don't wanna pay ridiculous price from BMW. They offer them for 120eur/100 GBP (150 USD) here in Europe.
In the process of trying to find what would fit, i learned that stock injectors are Bosch 0280150701.
Witchhunter say they are 236cc/min @ 3bar:
http://witchhunter.com/flowdatapix/b0280150701.jpg
I found out that few european cars run same injectors, like Fiat Punto GT Turbo 1.4 and Lancia Kappa V6 3.0 24v.
Also, some run very similar injectors like Saab 2.0 Turbo cars and Bosch 0280150706 injectors which have just few % higher flow rate.
What's imporatant is that new injectors are cheaper at Fiat/Lancia and Saab, also many shops quote less when you say you need them for Fiat and not BMW M3
There are also options to go with some higher flow rate injectors, most common and affordable are found on US Fords and similar cars.
In the mean time, i learned that these injectors are EV1, and plastic EV6 should be better regarding spray pattern. They cost similar money, so that's not an issue. What is a question is should i go with new type or stay with "good ol'" EV1.
Can anyone help, should i use EV6 on my S50B30 ? Maybe go higher flow rate just for the sake of safety (richer AFR) ?
Thanks
Thanks
