E36 windows don't do anything, can operate with scan tool
    Hey! I just picked up a 1995 e36 m3. When I turned the ignition on the windows rolled themselves down all the way and the window switches don't do anything at all. Occasionally, I'll press a window button and the windows will move a tiny but (both sides affected by either window switch). I can roll the windows up and down the whole range with a scan tool but can't do anything after that. I was looking through the forum and most issues seemed to have some sign of life or function but there is no click or movement most of the time when I press the switches. My hazards also turn on when I press the switch sometimes, this also happens when the car just sits with the ignition on so it could be the crash relay. Was wondering if anyone had any ideas. No codes on GM module or any other module. I removed an aftermarket alarm module to try to fix the issue but that didn't do anything (it only connected to oem pre-wried alarm harness). TIA!
