Hoping for some assistance.
2011.5 E90 M3
My master window switch stopped working altogether. Other windows can be put down with their respective switches, just driver window and all other switches on master control do not work.
I took door panel apart to inspect, but didn't see any issues with wiring. Car is only 48k and in fantastic condition, in Socal for all 11 years, so no rust or corrosion or anything anywhere.
So I bought a "good/tested" switch unit off ebay, but it doesn't work either
So I'm wondering, is there perhaps an error code in some module that needs to be cleared before the switch can work again?
Is there a module known to control this operation that should be inspected?
Is this a known issue? Searching, I see it mentioned a little, but it turned out to be corrosion in the wiring in one thread that had resolution.
Thanks
2011.5 E90 M3
Thanks
