513M + 15mm spacer (rear) + stock wheel bolts?
    Planning to run 513Ms with 15mm spacers in the rear to get close to stock offset. Any thoughts on whether the stock wheel bolts work safely, or whether I'll need longer bolts?
    2008 E90 M3 6MT
    2011 E90 328i 6MT
    RWD, slicktop, no iDrive
    There is no way stock bolts will work with 15mm spacers.
      Thanks. Suspected as much but thought it'd be worth asking.
      Related: I know where to get longer bolts, but I'd like wheel locks as well. Any suggestion on where to find the wheel locks?
      2008 E90 M3 6MT
      2011 E90 328i 6MT
        Turner has a good guide on what size is needed for each spacer size.
          https://www.turnermotorsport.com/p-3...pacers/?pdk=AQ
          Perfect. Thanks again!
          2008 E90 M3 6MT
          2011 E90 328i 6MT
            I switched to a stud kit specifically to avoid this. I can swap wheels/spacers up 12 mm using the same stud/nuts
