Rear brake (caliper) temp questions
    I have F8x brakes up front with the stock rears, so the rears are working a bit harder than they ordinarily would (pressure bias shifts rearward). I’ve had Alcon temp strips on the calipers for a few events this season; at the last one, they ended up 1-2 squares from maxed out (450º - 500º F / 230º - 255º C).
    2008 E90 M3
    ~Stock weight
    No aero
    245f/265r AD09 (endurance 200TW)
    Stock power minus whatever has escaped in >172k miles
    PFC 331/332 pads, OE rotors
    Questions:
    1. Are these temp readings normal?
    2. Any concern about dust boots and seals at these temps? This page seems to think so, but I’d value people’s lived experiences here as well.
    3. Without swapping to different calipers, is there anything I can do to manage these temps? All I’ve seen so far is this brake duct kit, and I have yet to see any posts about it installed on an E9x M3, let alone how effective it is.
    2008 E90 M3 6MT
    2011 E90 328i 6MT
    RWD, slicktop, no iDrive
    2) are they cracked/melted? Easy visual check when you're swapping pads.
    3) ... I want to print something like that
      I would use something much more precise and measurable than temperature strips to determine true temperature. IME, OE caliper boots smoke pretty well when they are cooking.
      Is this track or street experience?
        One was. But I'm not sure if that means much because it was original after 172k miles 😬
        In!
        Got it. No smoke AFAICT, so I'll take that as a good sign.
        I do have an IR thermometer with an emissivity setting. Wouldn't suck to calibrate that so I can use it....
        ​Track.
        2008 E90 M3 6MT
        2011 E90 328i 6MT
          Frenkit puts those temperature strips in every rebuild kit but like Estoril said, you need something more precise. Those oe boots are fine for the street but are not great at the track. DBA (Australian rotor mfg) did a great YouTube video comparing the dust boots. Seals also are measured on hardness (compression)
          mike
          ops
          High Temp Caliper Rebuild Kits For Brembo/Stoptech/Akebono
          www.ohioperformancesolutions.com
          2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp​
