Thanks for the props, guys. Just trying to put out something as honest, thoughtful, and useful as I can.
Review: 3DM Öhlins R&T kit + TMS camber plates + Syncro Design Works tension arms
Great review. I'm glad you took the time to write this up. I have an E60 M5 and I've been thinking about a custom setup also. It is essentially the same suspension design, but a bit heavier of a car. New stock struts/shocks are stupidly expensive, and it's approaching the price of one of these high end setups, KW and Bilstein have setups, but sometimes I'm a glutton for punishment. Did you do any theoretical calculations or simulation? Seems like you also have some background in vehicle dynamics too. I also have my own alignment machine, corner weighting scales, road force balancer, and tire machine.
Originally posted by hansbrix View PostGreat review. I'm glad you took the time to write this up. I have an E60 M5 and I've been thinking about a custom setup also. It is essentially the same suspension design, but a bit heavier of a car. New stock struts/shocks are stupidly expensive, and it's approaching the price of one of these high end setups, KW and Bilstein have setups, but sometimes I'm a glutton for punishment. Did you do any theoretical calculations or simulation? Seems like you also have some background in vehicle dynamics too. I also have my own alignment machine, corner weighting scales, road force balancer, and tire machine.
Man, I wish I had an actual background in vehicle dynamics. This is just a hobby for me, and not even one I've gotten that deep into.
When you say theoretical calculations, does that include plugging stuff into suspension calculator spreadsheets? 🤣 I did some of that mainly to try to assess ride frequencies and front/rear roll couples to see how feasible flat ride would be. As I mentioned in the second post, I ended up abandoning that effort, mainly because I couldn't imagine I had the juice to see it through when none of the real experts had even tried. Didn't do anything more sophisticated than that, let alone simulations.2008 M3 Sedan 6MT
2012 Mazda5 6MT
Koni Special Active, Volvo parts
Well that was along time ago and I neither had the time or money to do have a decent car. Time has since passed and I have some toys and tools now, it's a hobby for me too. But even back 20 years ago there were standalone programs where you could model the kinematics. I'm sure there are ex Fomula SAE nerds that have done a bunch of modeling. I also did quite a bit of chassis and ride development after college in an earlier life and I was impressed by your ability to articulate the subtleties of ride and handling trade offs. For obvisous reasons it seems only engineers tend to understand and can discuss these topics, it's a bit usually to see this level of intelligent discussion on forums.
I was catching up on more posts since I haven't been on the site for a while. I see you have your vibrations stuff sorted out. 6-7 lbs of force variation is pretty good, the default limit on the machine is set at 26 lbs if I recall correctly, but you can change that and the read out will tell you the exact force regardless. If it's really bad you can get a new tire under warranty, but that's tricky. I'm also in the NE so not very far away so if you needed to do an audit on your wheel/tire combo I could do it. I have a Hunter Road Force Touch.
spreadsheets are definitely valid. The fact that you even tried/did to calculate the ride frequencies and roll centers are impressive. The roll gradient is pretty important, but all this can be alot of theoretical tedium, where did you pick up how to do this stuff from? I used to use ADAMS and Matlab to crunch this stuff but you have to set up the model in program first, not hard, but tedious, a bit of a buzz kill too.
Originally posted by hansbrix View PostWell that was along time ago and I neither had the time or money to do have a decent car. Time has since passed and I have some toys and tools now, it's a hobby for me too. But even back 20 years ago there were standalone programs where you could model the kinematics. I'm sure there are ex Fomula SAE nerds that have done a bunch of modeling.
Originally posted by hansbrix View PostI also did quite a bit of chassis and ride development after college in an earlier life and I was impressed by your ability to articulate the subtleties of ride and handling trade offs. For obvisous reasons it seems only engineers tend to understand and can discuss these topics, it's a bit usually to see this level of intelligent discussion on forums.
Originally posted by hansbrix View PostI was catching up on more posts since I haven't been on the site for a while. I see you have your vibrations stuff sorted out. 6-7 lbs of force variation is pretty good, the default limit on the machine is set at 26 lbs if I recall correctly, but you can change that and the read out will tell you the exact force regardless. If it's really bad you can get a new tire under warranty, but that's tricky. I'm also in the NE so not very far away so if you needed to do an audit on your wheel/tire combo I could do it. I have a Hunter Road Force Touch.
Originally posted by hansbrix View Postspreadsheets are definitely valid. The fact that you even tried/did to calculate the ride frequencies and roll centers are impressive. The roll gradient is pretty important, but all this can be alot of theoretical tedium, where did you pick up how to do this stuff from? I used to use ADAMS and Matlab to crunch this stuff but you have to set up the model in program first, not hard, but tedious, a bit of a buzz kill too.
Couldn't assume the roll couple numbers I generated were accurate because I didn't have ARB motion ratios. However, I thought that if I used the same ARB motion ratios for every setup I wanted to compare, I could still use the calculated roll couples to get very rough estimates of how handling balance might change.
Here's the main spreadsheet I used. Took a fair bit of editing,
For stock spring rates, I used 160 lbs/ft front and 550 or 600 lbs/ft rear. Saw those online in various places. For spring motion ratios, I used 0.96 front and 0.57 rear per this thread.
I got ARB rates from this page from Eibach..2008 M3 Sedan 6MT
2012 Mazda5 6MT
Edit: never mind I just realized Bilstein's catalog for E60 M5 cars is pretty bleak.Last edited by r4dr; 10-27-2020, 10:50 PM.'03.5 M3 SMG Coupe - Jet Black / Black
Originally posted by hansbrix View PostI also have my own alignment machine, corner weighting scales, road force balancer, and tire machine.
Funny you say that, it's so random, since I actually I have a few Hunter RF balancers, long story. I was going to post one for sale on CL, but been busy. I never thought about posting it up here. I have a transformer setup so it runs on 125V. (they are 220V single phase machines). I also can't stand anyone else touching my car because they always eff stuff up. Rotating the tire on the rim is a major pain and I do see why they don't do that unless you pay them extra. It's almost 2x the work. Where are you? you can come check them out. I have a forklift so I load it for you no prob.
Originally posted by hansbrix View PostFunny you say that, it's so random, since I actually I have a few Hunter RF balancers, long story. I was going to post one for sale on CL, but been busy. I never thought about posting it up here. I have a transformer setup so it runs on 125V. (they are 220V single phase machines). I also can't stand anyone else touching my car because they always eff stuff up. Rotating the tire on the rim is a major pain and I do see why they don't do that unless you pay them extra. It's almost 2x the work. Where are you? you can come check them out. I have a forklift so I load it for you no prob.
I'm in South FL so pretty far from NE state, otherwise I'd take you up on that.
I thought the total power requirement would not support what I could do with a transformer, but I've never had it trip out. The Hunter Road Force balancers need air to operate the load roller also. I run that and the tire machine off a small dewalt/emglo air compressor like what you see at Home Despot, I never have them running at the same time though. Tire machines have a big tank in the column or somewhere else because it uses a dump valve to seat the beads. I chose all my stuff so that I could put it in a trailer if I wanted (and had a trailer and half ton truck for track days). It's a time or money thing. also when I said NE I meant North East or New England not Nebraska, but I guess someone told me NJ is in a mid atlantic state, certainly not New England. I'm clearly not a native.
Eibach Pro-Kit springs + Bilstein B8s should be right around $1000 right? That would be well short of a full, $$$ setup. Are you DDing this car?
Wow, TIL. The E93 is hefty hefty.
If you take the non M versions, and compare same engine, same trans, same drivetrain, body (so, say, rwd 528i 6mt sedan vs rwd 328i 6mt sedan), the e60 is only ~70 lbs heavier than the e90. BMW had to do a ton of work to get the e9X M3 to be lighter (plastic fenders, CF rood, etc), and they still only ended up ~300 lbs lighter for similarly speced cars (e90 M3 vs e60 M5).
On top of that, the hardtop vert adds a ton of weight to the e9X.
