MSS60 Research
  • terra
    Originally posted by dpaul View Post
    You are first.
    I feel I have searched exhaustively and PM'd everyone who seemed to have even a shred of relevant information. There are few comments out there from people who thought they knew how to do it or even claim to have done it. But no one sharing any useful information or proof of the accomplishment.
    Again, awesome.
    Yeah, I saw the usual internet badasses who claimed that had some knowledge of the dark arts and could do it. But no one who said how.
    Even if I do come up with a good script (effectively all I did was disable the watchdog and then follow the steps in the reference manual on setting / clearing the censor), I do think this is unfortunately a bit beyond most people. Fewer and fewer people own desktops nowadays, which is pretty much required for the PCIe parallel port (USB will not work). I guess an expresscard parallel port should work, but how many laptops even have expresscard nowadays? Thunderbolt to PCIe or exprescard adapters do exist, but at that point you may as well buy the more expensive pemicro stuff.
    And the reality is even back when they were mainstream, parallel ports have always been notoriously finicky - there will be trouble shooting involved no matter what.
    Just noticed this in the Macgraigor FAQ:
    "What mode must my parallel port be in?
    As far as the parallel port is concerned, a Wiggler is a simple uni-directional device. It will work with the parallel port in any mode EXCEPT "ECP". It will NOT work in ECP mode at all.
    The Raven works best with a parallel port in EPP mode. It may work in ECP mode. If the parallel port is in an older mode, such as uni-directional, AT, or compatible, the Raven will work but slower."
    So its a feature, not a bug
    Ha I saw the ECP part, but I didn't notice the "simple uni-directional device" part. I guess that must relate to individual pin behavior rather than the device as a whole? In any case, I did have to force the virtual bios to "output only" rather than bidirectional or EPP.
  • dpaul
    I got the interface working. Had to set the parallel port mode in the VM bios to "Output Only" instead of bidirectional / EPP / ECP. Doesn't really make sense to me since it seems like communications are going both ways... but who knows.
  • Martyn
    Basically yep. BDM flash finished, and I confirmed the DME is responsive now.
    I think I'm the first to successfully unlock one of these DMEs. Publicly anyway
    You have a factory unlocked MSS60 right? When you get the chance do you think you'd be able to read the shadow memory from it? CMDFlash just tacks it onto the end of the internal flash, not sure about others. I made the assumption that the shadow memory from the MSS65 is good enough (and it probably is), but I just want to be sure there isn't anything different.
    My bench MSS60 is dead unfortunately
  • dpaul
    You are first.
    Again, awesome.
  • terra
    Great progress Mirza, so the register is now set to 41FF00FF the same as both processors like the factory MSS65?
  • Martyn
  • terra
    Boom.
    Click image for larger version  Name:	AndWereBack.png Views:	0 Size:	19.7 KB ID:	15419
    Turns out clearing / setting the censor disables the UC3F array altogether, but you can reenable that by setting the IMMR.
    Now I gotta see if I could make a script to automate all this.
    Confirmed BDM100 will now read the DME (all FF'd of course). Now I'm just flashing back my OBDII backup (along with the shadow region from the MSS65 hoping it's the same here) and hopefully it will work.
  • terra
    Click image for larger version  Name:	ItWorksIthink.png Views:	0 Size:	25.9 KB ID:	15380
    This is my MSS65, but I'll try the MSS60 next. I guess I would just manually set the registers as noted in the reference manual
    Edit: Meh, I clearly have some reading to do. Except you know, macraigor has literally 0 documentation. On this DME I can pretty much only do 1 command before I start getting junk or FFs back. I guess I'm running into the watchdog or something?
    Edit: Sigh, I think I broke it. I managed to change the censor bytes from 11 to 00. But then when I tried setting to 01, all of the UC3F registers started reading as FF, and manipulating them seemingly doesn't work. DME doesn't boot anymore, and BDM100 still treats it the same as before.
  • terra
    Nothing in the manual but there is a routine in the "Algorithms for MPC5xx/8xx, internal flash" download for enabling the shadow memory where the UC3F control block is located. Even a warning about losing the contents of the internal flash.
    Seems like it should be able to change the UC3FMCR register. But at $200, it would be greatly disappointing if it didn't work.
    Yeah, on one hand, it'd probably be a nicer programmer than my clone BDM100. Especially since if you forget the pinout on that is non-standard, you'll be sending 12V into the MCU and killing it.
    On the other hand, I don't exactly need it, but could justify it if it kills the censor.
  • dpaul
    Sigh, I guess my basement is not very hospitable to old electronics. My old CPU/mobo combos won't post.
    There's a few PEMicro Cyclone Maxes on eBay for not crazy money. And with the Cyclones, it sounds like the programming software is free (you can download it right from PEMicro's website). Maybe I should just buy one of those.
    What concerns me t hough is the user manual doesn't actually mention anything about clearing the censor for the MPC5xx / 8xx.
  • terra
  • dpaul
    I got an older version of OCDCommander via archive.org and got a little farther. The program will now actually be able to tell if the CPU is on / off, and it will read at least a few registers correctly before returning junk data. I wonder if it's something as simple as the clock speed being too damn high.
    Try loading the ediabslib dll itself as a resource.
    thanks - I did get the binary - all is good. Would think it should compile tho.
  • terra
    That is frustrating - could be a hardware problem with the wiggler or a problem with the virtual machine - I guess finding/setting up an old computer is the only way to know.
    Can I ask an unrelated question? I promise I will not bother you further with random coding questions. I've been unable to compile EdiabasLib. I downloaded it today and am using Visual Studio 2019. Using the make file EdiabasLib.sln, I am getting the following errors:
    Click image for larger version Name:	Capture.JPG Views:	0 Size:	41.9 KB ID:	15115
    EDIT: Nevermind. I'll get the binaries.
  • dpaul
  • terra
    So I got my wiggler in, but I'm not sure it's working right. Setup a new XP virtual machine and ran macraigor's OCD Commander to see if I could get some basic info out of the CPU - http://www.macraigor.com/ocd_cmd.htm
    Getting pretty much junk data though. It works enough that it can tell when the device isn't connected to the parallel port, but otherwise I get junk data out of it whether or not I'm hooked up to the BDM header. Messing with the ECP/EPP settings within the VM bios didn't make a difference. Not sure if there's anything I could mess with at the host side to help.
    I'm half tempted to pull one of my old motherboards/processors with a native parallel port out of storage.. but that sounds painful frankly.
