EWS delete testing
  • ZiMMie
    Sure location?
  • hobbit382
    is the same location for the MS65?
    can you get me a ram read while the engine is running, also with it key on engine off, and a ram read of a spare dme? I’ll start working on a solution for mss65 as well.
    most of the code that’s in mss65 is in mss60, although it appears that mss60 doesn’t use it. Maybe the difference between ews3 and ews4
  • CF-CarParts Motorsport
    MSS65 immo off not same as mss60 but nearly almost to it.
    MSS70, MSV70 both also arent as far away (most, some of this xxxxx different (MSS70)).
    MSV8x, MSD8x is different .
  • hobbit382
    I highly doubt it, but I haven’t checked mss65 yet
    edit: that section of code doesn’t exist in mss65
  • ZiMMie
    I can test it next to two weeks, after the vacation and be back to shop.
    Isn't same as I did but who knows - many ways to rom .
  • hobbit382
    Hopefully some others will be willing to try as well.
  • MpowerE36
    Originally posted by hobbit382 View Post
    I’ve been working on ews delete for everyone, but don’t always have a car available to test on. If anyone has a spare dme and would like to do some testing change byte 0x65387 from 03 to 01 and report back.
    If I unbrick my spare MSS60, I will work on the m3 e90 of my friend and I will test what you are suggesting. However it will be at the beginning of september.
  • hobbit382
    started a topic EWS delete testing
    EWS delete testing
    update: tested and confirmed
    Mss60 241E
    (Confirmed)
    Mss65 160E
    change address 0x60FBC from 40 82 to 48 00 (confirmed)
    MSS65 520E
    change address 0x62DA8 from 40 82 to 48 00 (confirmed)
    special thanks to Terra, for all the hard work he has put into this flasher and everything else!
