MSS60 241E / 7854376 daten files
    Anyone have the datens containing 241E / 784376? The V60.1 E89 datens don't appear to contain it
    Are you sure? The file names are a little weird since BMW didn't actually change the tunes between 240E and 241E
    Code:
    [B]7854376,7838840,7854317,A,7848136DA,0FFFFFFFFFD,00 0,1 G[/B]
    7854375,7838841,7854317,A,7848134DA,0FFFFFFFFFD,00 0,1 8
    7854371,7844915,7854317,A,7850264DA,0FFFFFFFFFD,00 0,1 I
    7854372,7844915,7854317,A,7848128DA,0FFFFFFFFFD,00 0,1 V
    7854373,7843727,7854317,A,7848130DA,0FFFFFFFFFD,00 0,1 B
    7854377,7838724,7854317,A,7848138DA,0FFFFFFFFFD,00 0,1 M
    7854374,7838724,7854317,A,7848132DA,0FFFFFFFFFD,00 0,1 V
    Should correspond to M7848136.0da
      Ah, it's the program version which is 241E (7854317A.0pa), the software version stays at 240 potentially....
        Yep. Basically the 3rd digit indicates that they made a program change without actually changing the tune layout. The DME doesn't enforce that particular digit matching. BMW didn't bother updating the tunes when they updated the program in that instance.
          Hello people
          after talking with ecuworx team for flashing update 240E i have dtc code when i start the car DTC Number 2778.
          I have m3 e92 euro spec and the file flashed i think is us spec after checking.
          now i need your help boys
          How i can flash update with euro spec ?
          or if possible to any body delete the dtc code from file.
          maybe the problem in my sp daten ?
            2778 means "DMTL-Heater". Post fullread and I will clear this one.
              Sorry dtc is 2776
                here my file thx
                  Do you want ->
                  - flash Euro spec?
                  - remove current DTC from file?
                  - remove DMTL function from current file?
                  Full file is not necessary, please upload partial file.
