MPC63 Processor Spec File for Ghidra
    If it's useful to anyone, here's a definition file for ghidra I put together. Based off the default PPC language file so nothing fancy, just creates most of the MPC563 memory map properly.
    <?xml version="1.0" encoding="UTF-8"?>
    <processor_spec>
    <properties>
    <property key="addressesDoNotAppearDirectlyInCode" value="true"/>
    <property key="emulateInstructionStateModifierClass" value="ghidra.program.emulation.PPCEmulateInstruct ionStateModifier"/>
    <property key="assemblyRating:PowerPC:BE:32:default" value="PLATINUM"/>
    </properties>
    <programcounter register="pc"/>
    <context_data>
    <context_set space="ram">
    <set name="linkreg" val="0"/>
    </context_set>
    </context_data>
    <default_memory_blocks>
    <memory_block name="DECRAM SRAM Array" start_address="0x2f8000" length="0x800" mode="rw" initialized="false"/>
    <memory_block name="BBC" start_address="0x2fa000" length="0x3F" mode="rw" initialized="false"/>
    <memory_block name="USIU" start_address="0x2fc000" length="0x3FF" mode="rw" initialized="false"/>
    <memory_block name="CDR3 Flash Control" start_address="0x2fc800" length="0x12" mode="rw" initialized="false"/>
    <memory_block name="DPTRAM Control Registers" start_address="0x300000" length="0xB" mode="rw" initialized="false"/>
    <memory_block name="DPTRAM Arrays" start_address="0x302000" length="0x7FF" mode="rw" initialized="false"/>
    <memory_block name="TPU3_A" start_address="0x304000" length="0x1FF" mode="rw" initialized="false"/>
    <memory_block name="TPU3_B" start_address="0x304400" length="0x1FF" mode="rw" initialized="false"/>
    <memory_block name="QADC A" start_address="0x304800" length="0x3FF" mode="rw" initialized="false"/>
    <memory_block name="QADC B" start_address="0x304c00" length="0x3FF" mode="rw" initialized="false"/>
    <memory_block name="QSMCM" start_address="0x305000" length="0x1DF" mode="rw" initialized="false"/>
    <memory_block name="PPM" start_address="0x305c00" length="0x2B" mode="rw" initialized="false"/>
    <memory_block name="MIOS14" start_address="0x306000" length="0xC71" mode="rw" initialized="false"/>
    <memory_block name="TouCAN A" start_address="0x307080" length="0x17F" mode="rw" initialized="false"/>
    <memory_block name="TouCAN B" start_address="0x307480" length="0x17F" mode="rw" initialized="false"/>
    <memory_block name="TouCAN C" start_address="0x307880" length="0x17F" mode="rw" initialized="false"/>
    <memory_block name="UIMB" start_address="0x307f80" length="0x24" mode="rw" initialized="false"/>
    <memory_block name="CALRAM Control Registers" start_address="0x380000" length="0x2F" mode="rw" initialized="false"/>
    <memory_block name="CALRAM Array" start_address="0x3f8000" length="0x7FFF" mode="rw" initialized="false"/>
    </default_memory_blocks>
    TODO: the renamed SPR registers below should be reviewed to
    accurately reflect a particular 32-bit PPC variant or a "common" standard
    set of SPR registers found in most variants.
    <register_data>
    <register name="spr000" group="SPR_UNNAMED"/>
    <register name="XER" group="SPR"/>
    <register name="spr002" group="SPR_UNNAMED"/>
    <register name="spr003" group="SPR_UNNAMED"/>
    <register name="spr004" group="SPR_UNNAMED"/>
    <register name="spr005" group="SPR_UNNAMED"/>
    <register name="spr006" group="SPR_UNNAMED"/>
    <register name="spr007" group="SPR_UNNAMED"/>
    <register name="LR" group="SPR"/>
    <register name="CTR" group="SPR"/>
    <register name="spr00a" group="SPR_UNNAMED"/>
    <register name="spr00b" group="SPR_UNNAMED"/>
    <register name="spr00c" group="SPR_UNNAMED"/>
    <register name="spr00d" group="SPR_UNNAMED"/>
    <register name="spr00e" group="SPR_UNNAMED"/>
    <register name="spr00f" group="SPR_UNNAMED"/>
    <register name="spr010" group="SPR_UNNAMED"/>
    <register name="spr011" group="SPR_UNNAMED"/>
    <register name="spr012" rename="DSISR" group="SPR"/>
    <register name="spr013" rename="DAR" group="SPR"/>
    <register name="spr014" group="SPR_UNNAMED"/>
    <register name="spr015" group="SPR_UNNAMED"/>
    <register name="spr016" rename="DEC" group="SPR"/>
    <register name="spr017" group="SPR_UNNAMED"/>
    <register name="spr018" group="SPR_UNNAMED"/>
    <register name="spr019" rename="SDR1" group="SPR"/>
    <register name="SRR0" group="SPR"/>
    <register name="SRR1" group="SPR"/>
    <register name="spr01c" group="SPR_UNNAMED"/>
    <register name="spr01d" group="SPR_UNNAMED"/>
    <register name="spr01e" group="SPR_UNNAMED"/>
    <register name="spr01f" group="SPR_UNNAMED"/>
    <register name="spr020" group="SPR_UNNAMED"/>
    <register name="spr021" group="SPR_UNNAMED"/>
    <register name="spr022" group="SPR_UNNAMED"/>
    <register name="spr023" group="SPR_UNNAMED"/>
    <register name="spr024" group="SPR_UNNAMED"/>
    <register name="spr025" group="SPR_UNNAMED"/>
    <register name="spr026" group="SPR_UNNAMED"/>
    <register name="spr027" group="SPR_UNNAMED"/>
    <register name="spr028" group="SPR_UNNAMED"/>
    <register name="spr029" group="SPR_UNNAMED"/>
    <register name="spr02a" group="SPR_UNNAMED"/>
    <register name="spr02b" group="SPR_UNNAMED"/>
    <register name="spr02c" group="SPR_UNNAMED"/>
    <register name="spr02d" group="SPR_UNNAMED"/>
    <register name="spr02e" group="SPR_UNNAMED"/>
    <register name="spr02f" group="SPR_UNNAMED"/>
    <register name="spr030" group="SPR_UNNAMED"/>
    <register name="spr031" group="SPR_UNNAMED"/>
    <register name="spr032" group="SPR_UNNAMED"/>
    <register name="spr033" group="SPR_UNNAMED"/>
    <register name="spr034" group="SPR_UNNAMED"/>
    <register name="spr035" group="SPR_UNNAMED"/>
    <register name="spr036" rename="DECAR" group="SPR"/>
    <register name="spr037" group="SPR_UNNAMED"/>
    <register name="spr038" group="SPR_UNNAMED"/>
    <register name="spr039" group="SPR_UNNAMED"/>
    <register name="CSRR0" group="SPR"/>
    <register name="CSRR1" group="SPR"/>
    <register name="spr03c" group="SPR_UNNAMED"/>
    <register name="spr03d" group="SPR_UNNAMED"/>
    <register name="spr03e" group="SPR_UNNAMED"/>
    <register name="spr03f" rename="IVPR" group="SPR"/>
    <register name="spr040" group="SPR_UNNAMED"/>
    <register name="spr041" group="SPR_UNNAMED"/>
    <register name="spr042" group="SPR_UNNAMED"/>
    <register name="spr043" group="SPR_UNNAMED"/>
    <register name="spr044" group="SPR_UNNAMED"/>
    <register name="spr045" group="SPR_UNNAMED"/>
    <register name="spr046" group="SPR_UNNAMED"/>
    <register name="spr047" group="SPR_UNNAMED"/>
    <register name="spr048" group="SPR_UNNAMED"/>
    <register name="spr049" group="SPR_UNNAMED"/>
    <register name="spr04a" group="SPR_UNNAMED"/>
    <register name="spr04b" group="SPR_UNNAMED"/>
    <register name="spr04c" group="SPR_UNNAMED"/>
    <register name="spr04d" group="SPR_UNNAMED"/>
    <register name="spr04e" group="SPR_UNNAMED"/>
    <register name="spr04f" group="SPR_UNNAMED"/>
    <register name="spr050" rename="EIE" group="SPR"/>
    <register name="spr051" rename="EID" group="SPR"/>
    <register name="spr052" rename="NRI" group="SPR"/>
    <register name="spr053" group="SPR_UNNAMED"/>
    <register name="spr054" group="SPR_UNNAMED"/>
    <register name="spr055" group="SPR_UNNAMED"/>
    <register name="spr056" group="SPR_UNNAMED"/>
    <register name="spr057" group="SPR_UNNAMED"/>
    <register name="spr058" group="SPR_UNNAMED"/>
    <register name="spr059" group="SPR_UNNAMED"/>
    <register name="spr05a" group="SPR_UNNAMED"/>
    <register name="spr05b" group="SPR_UNNAMED"/>
    <register name="spr05c" group="SPR_UNNAMED"/>
    <register name="spr05d" group="SPR_UNNAMED"/>
    <register name="spr05e" group="SPR_UNNAMED"/>
    <register name="spr05f" group="SPR_UNNAMED"/>
    <register name="spr060" group="SPR_UNNAMED"/>
    <register name="spr061" group="SPR_UNNAMED"/>
    <register name="spr062" group="SPR_UNNAMED"/>
    <register name="spr063" group="SPR_UNNAMED"/>
    <register name="spr064" group="SPR_UNNAMED"/>
    <register name="spr065" group="SPR_UNNAMED"/>
    <register name="spr066" group="SPR_UNNAMED"/>
    <register name="spr067" group="SPR_UNNAMED"/>
    <register name="spr068" group="SPR_UNNAMED"/>
    <register name="spr069" group="SPR_UNNAMED"/>
    <register name="spr06a" group="SPR_UNNAMED"/>
    <register name="spr06b" group="SPR_UNNAMED"/>
    <register name="spr06c" group="SPR_UNNAMED"/>
    <register name="spr06d" group="SPR_UNNAMED"/>
    <register name="spr06e" group="SPR_UNNAMED"/>
    <register name="spr06f" group="SPR_UNNAMED"/>
    <register name="spr070" group="SPR_UNNAMED"/>
    <register name="spr071" group="SPR_UNNAMED"/>
    <register name="spr072" group="SPR_UNNAMED"/>
    <register name="spr073" group="SPR_UNNAMED"/>
    <register name="spr074" group="SPR_UNNAMED"/>
    <register name="spr075" group="SPR_UNNAMED"/>
    <register name="spr076" group="SPR_UNNAMED"/>
    <register name="spr077" group="SPR_UNNAMED"/>
    <register name="spr078" group="SPR_UNNAMED"/>
    <register name="spr079" group="SPR_UNNAMED"/>
    <register name="spr07a" group="SPR_UNNAMED"/>
    <register name="spr07b" group="SPR_UNNAMED"/>
    <register name="spr07c" group="SPR_UNNAMED"/>
    <register name="spr07d" group="SPR_UNNAMED"/>
    <register name="spr07e" group="SPR_UNNAMED"/>
    <register name="spr07f" group="SPR_UNNAMED"/>
    <register name="spr080" group="SPR_UNNAMED"/>
    <register name="spr081" group="SPR_UNNAMED"/>
    <register name="spr082" group="SPR_UNNAMED"/>
    <register name="spr083" group="SPR_UNNAMED"/>
    <register name="spr084" group="SPR_UNNAMED"/>
    <register name="spr085" group="SPR_UNNAMED"/>
    <register name="spr086" group="SPR_UNNAMED"/>
    <register name="spr087" group="SPR_UNNAMED"/>
    <register name="spr088" group="SPR_UNNAMED"/>
    <register name="spr089" group="SPR_UNNAMED"/>
    <register name="spr08a" group="SPR_UNNAMED"/>
    <register name="spr08b" group="SPR_UNNAMED"/>
    <register name="spr08c" group="SPR_UNNAMED"/>
    <register name="spr08d" group="SPR_UNNAMED"/>
    <register name="spr08e" group="SPR_UNNAMED"/>
    <register name="spr08f" group="SPR_UNNAMED"/>
    <register name="spr090" rename="CMPA" group="SPR"/>
    <register name="spr091" rename="CMPB" group="SPR"/>
    <register name="spr092" rename="CMPC" group="SPR"/>
    <register name="spr093" rename="CMPD" group="SPR"/>
    <register name="spr094" rename="ECR" group="SPR"/>
    <register name="spr095" rename="DER" group="SPR"/>
    <register name="spr096" rename="COUNTA" group="SPR"/>
    <register name="spr097" rename="COUNTB" group="SPR"/>
    <register name="spr098" rename="CMPE" group="SPR"/>
    <register name="spr099" rename="CMPF" group="SPR"/>
    <register name="spr09a" rename="CMPH" group="SPR"/>
    <register name="spr09b" rename="LCTR1" group="SPR"/>
    <register name="spr09c" rename="LCTR2" group="SPR"/>
    <register name="spr09d" rename="ICTRL" group="SPR"/>
    <register name="spr09e" rename="BAR" group="SPR"/>
    <register name="spr09f" group="SPR_UNNAMED"/>
    <register name="spr0a0" group="SPR_UNNAMED"/>
    <register name="spr0a1" group="SPR_UNNAMED"/>
    <register name="spr0a2" group="SPR_UNNAMED"/>
    <register name="spr0a3" group="SPR_UNNAMED"/>
    <register name="spr0a4" group="SPR_UNNAMED"/>
    <register name="spr0a5" group="SPR_UNNAMED"/>
    <register name="spr0a6" group="SPR_UNNAMED"/>
    <register name="spr0a7" group="SPR_UNNAMED"/>
    <register name="spr0a8" group="SPR_UNNAMED"/>
    <register name="spr0a9" group="SPR_UNNAMED"/>
    <register name="spr0aa" group="SPR_UNNAMED"/>
    <register name="spr0ab" group="SPR_UNNAMED"/>
    <register name="spr0ac" group="SPR_UNNAMED"/>
    <register name="spr0ad" group="SPR_UNNAMED"/>
    <register name="spr0ae" group="SPR_UNNAMED"/>
    <register name="spr0af" group="SPR_UNNAMED"/>
    <register name="spr0b0" group="SPR_UNNAMED"/>
    <register name="spr0b1" group="SPR_UNNAMED"/>
    <register name="spr0b2" group="SPR_UNNAMED"/>
    <register name="spr0b3" group="SPR_UNNAMED"/>
    <register name="spr0b4" group="SPR_UNNAMED"/>
    <register name="spr0b5" group="SPR_UNNAMED"/>
    <register name="spr0b6" group="SPR_UNNAMED"/>
    <register name="spr0b7" group="SPR_UNNAMED"/>
    <register name="spr0b8" group="SPR_UNNAMED"/>
    <register name="spr0b9" group="SPR_UNNAMED"/>
    <register name="spr0ba" group="SPR_UNNAMED"/>
    <register name="spr0bb" group="SPR_UNNAMED"/>
    <register name="spr0bc" group="SPR_UNNAMED"/>
    <register name="spr0bd" group="SPR_UNNAMED"/>
    <register name="spr0be" group="SPR_UNNAMED"/>
    <register name="spr0bf" group="SPR_UNNAMED"/>
    <register name="spr0c0" group="SPR_UNNAMED"/>
    <register name="spr0c1" group="SPR_UNNAMED"/>
    <register name="spr0c2" group="SPR_UNNAMED"/>
    <register name="spr0c3" group="SPR_UNNAMED"/>
    <register name="spr0c4" group="SPR_UNNAMED"/>
    <register name="spr0c5" group="SPR_UNNAMED"/>
    <register name="spr0c6" group="SPR_UNNAMED"/>
    <register name="spr0c7" group="SPR_UNNAMED"/>
    <register name="spr0c8" group="SPR_UNNAMED"/>
    <register name="spr0c9" group="SPR_UNNAMED"/>
    <register name="spr0ca" group="SPR_UNNAMED"/>
    <register name="spr0cb" group="SPR_UNNAMED"/>
    <register name="spr0cc" group="SPR_UNNAMED"/>
    <register name="spr0cd" group="SPR_UNNAMED"/>
    <register name="spr0ce" group="SPR_UNNAMED"/>
    <register name="spr0cf" group="SPR_UNNAMED"/>
    <register name="spr0d0" group="SPR_UNNAMED"/>
    <register name="spr0d1" group="SPR_UNNAMED"/>
    <register name="spr0d2" group="SPR_UNNAMED"/>
    <register name="spr0d3" group="SPR_UNNAMED"/>
    <register name="spr0d4" group="SPR_UNNAMED"/>
    <register name="spr0d5" group="SPR_UNNAMED"/>
    <register name="spr0d6" group="SPR_UNNAMED"/>
    <register name="spr0d7" group="SPR_UNNAMED"/>
    <register name="spr0d8" group="SPR_UNNAMED"/>
    <register name="spr0d9" group="SPR_UNNAMED"/>
    <register name="spr0da" group="SPR_UNNAMED"/>
    <register name="spr0db" group="SPR_UNNAMED"/>
    <register name="spr0dc" group="SPR_UNNAMED"/>
    <register name="spr0dd" group="SPR_UNNAMED"/>
    <register name="spr0de" group="SPR_UNNAMED"/>
    <register name="spr0df" group="SPR_UNNAMED"/>
    <register name="spr0e0" group="SPR_UNNAMED"/>
    <register name="spr0e1" group="SPR_UNNAMED"/>
    <register name="spr0e2" group="SPR_UNNAMED"/>
    <register name="spr0e3" group="SPR_UNNAMED"/>
    <register name="spr0e4" group="SPR_UNNAMED"/>
    <register name="spr0e5" group="SPR_UNNAMED"/>
    <register name="spr0e6" group="SPR_UNNAMED"/>
    <register name="spr0e7" group="SPR_UNNAMED"/>
    <register name="spr0e8" group="SPR_UNNAMED"/>
    <register name="spr0e9" group="SPR_UNNAMED"/>
    <register name="spr0ea" group="SPR_UNNAMED"/>
    <register name="spr0eb" group="SPR_UNNAMED"/>
    <register name="spr0ec" group="SPR_UNNAMED"/>
    <register name="spr0ed" group="SPR_UNNAMED"/>
    <register name="spr0ee" group="SPR_UNNAMED"/>
    <register name="spr0ef" group="SPR_UNNAMED"/>
    <register name="spr0f0" group="SPR_UNNAMED"/>
    <register name="spr0f1" group="SPR_UNNAMED"/>
    <register name="spr0f2" group="SPR_UNNAMED"/>
    <register name="spr0f3" group="SPR_UNNAMED"/>
    <register name="spr0f4" group="SPR_UNNAMED"/>
    <register name="spr0f5" group="SPR_UNNAMED"/>
    <register name="spr0f6" group="SPR_UNNAMED"/>
    <register name="spr0f7" group="SPR_UNNAMED"/>
    <register name="spr0f8" group="SPR_UNNAMED"/>
    <register name="spr0f9" group="SPR_UNNAMED"/>
    <register name="spr0fa" group="SPR_UNNAMED"/>
    <register name="spr0fb" group="SPR_UNNAMED"/>
    <register name="spr0fc" group="SPR_UNNAMED"/>
    <register name="spr0fd" group="SPR_UNNAMED"/>
    <register name="spr0fe" group="SPR_UNNAMED"/>
    <register name="spr0ff" group="SPR_UNNAMED"/>
    <register name="spr100" rename="USPRG0" group="SPR"/>
    <register name="spr101" group="SPR_UNNAMED"/>
    <register name="spr102" group="SPR_UNNAMED"/>
    <register name="spr103" group="SPR_UNNAMED"/>
    <register name="spr104" rename="SPRG41" group="SPR"/>
    <register name="spr105" rename="SPRG51" group="SPR"/>
    <register name="spr106" rename="SPRG61" group="SPR"/>
    <register name="spr107" rename="SPRG71" group="SPR"/>
    <register name="spr108" group="SPR_UNNAMED"/>
    <register name="spr109" group="SPR_UNNAMED"/>
    <register name="spr10a" group="SPR_UNNAMED"/>
    <register name="spr10b" group="SPR_UNNAMED"/>
    <register name="TBLr" group="SPR"/>
    <register name="TBUr" group="SPR"/>
    <register name="spr10e" group="SPR_UNNAMED"/>
    <register name="spr10f" group="SPR_UNNAMED"/>
    <register name="spr110" rename="SPRG0" group="SPR"/>
    <register name="spr111" rename="SPRG1" group="SPR"/>
    <register name="spr112" rename="SPRG2" group="SPR"/>
    <register name="spr113" rename="SPRG3" group="SPR"/>
    <register name="spr114" rename="SPRG4" group="SPR"/>
    <register name="spr115" rename="SPRG5" group="SPR"/>
    <register name="spr116" rename="SPRG6" group="SPR"/>
    <register name="spr117" rename="SPRG7" group="SPR"/>
    <register name="spr118" rename="ASR" group="SPR"/>
    <register name="spr119" group="SPR_UNNAMED"/>
    <register name="spr11a" rename="EAR" group="SPR"/>
    <register name="spr11b" group="SPR_UNNAMED"/>
    <register name="TBLw" group="SPR"/>
    <register name="TBUw" group="SPR"/>
    <register name="spr11e" group="SPR_UNNAMED"/>
    <register name="spr11f" rename="PVR" group="SPR"/>
    <register name="spr120" group="SPR_UNNAMED"/>
    <register name="spr121" group="SPR_UNNAMED"/>
    <register name="spr122" group="SPR_UNNAMED"/>
    <register name="spr123" group="SPR_UNNAMED"/>
    <register name="spr124" group="SPR_UNNAMED"/>
    <register name="spr125" group="SPR_UNNAMED"/>
    <register name="spr126" group="SPR_UNNAMED"/>
    <register name="spr127" group="SPR_UNNAMED"/>
    <register name="spr128" group="SPR_UNNAMED"/>
    <register name="spr129" group="SPR_UNNAMED"/>
    <register name="spr12a" group="SPR_UNNAMED"/>
    <register name="spr12b" group="SPR_UNNAMED"/>
    <register name="spr12c" group="SPR_UNNAMED"/>
    <register name="spr12d" group="SPR_UNNAMED"/>
    <register name="spr12e" group="SPR_UNNAMED"/>
    <register name="spr12f" group="SPR_UNNAMED"/>
    <register name="spr130" group="SPR_UNNAMED"/>
    <register name="spr131" group="SPR_UNNAMED"/>
    <register name="spr132" group="SPR_UNNAMED"/>
    <register name="spr133" group="SPR_UNNAMED"/>
    <register name="spr134" group="SPR_UNNAMED"/>
    <register name="spr135" group="SPR_UNNAMED"/>
    <register name="spr136" group="SPR_UNNAMED"/>
    <register name="spr137" group="SPR_UNNAMED"/>
    <register name="spr138" group="SPR_UNNAMED"/>
    <register name="spr139" group="SPR_UNNAMED"/>
    <register name="spr13a" group="SPR_UNNAMED"/>
    <register name="spr13b" group="SPR_UNNAMED"/>
    <register name="spr13c" group="SPR_UNNAMED"/>
    <register name="spr13d" group="SPR_UNNAMED"/>
    <register name="spr13e" group="SPR_UNNAMED"/>
    <register name="spr13f" group="SPR_UNNAMED"/>
    <register name="spr140" group="SPR_UNNAMED"/>
    <register name="spr141" group="SPR_UNNAMED"/>
    <register name="spr142" group="SPR_UNNAMED"/>
    <register name="spr143" group="SPR_UNNAMED"/>
    <register name="spr144" group="SPR_UNNAMED"/>
    <register name="spr145" group="SPR_UNNAMED"/>
    <register name="spr146" group="SPR_UNNAMED"/>
    <register name="spr147" group="SPR_UNNAMED"/>
    <register name="spr148" group="SPR_UNNAMED"/>
    <register name="spr149" group="SPR_UNNAMED"/>
    <register name="spr14a" group="SPR_UNNAMED"/>
    <register name="spr14b" group="SPR_UNNAMED"/>
    <register name="spr14c" group="SPR_UNNAMED"/>
    <register name="spr14d" group="SPR_UNNAMED"/>
    <register name="spr14e" group="SPR_UNNAMED"/>
    <register name="spr14f" group="SPR_UNNAMED"/>
    <register name="spr150" group="SPR_UNNAMED"/>
    <register name="spr151" group="SPR_UNNAMED"/>
    <register name="spr152" group="SPR_UNNAMED"/>
    <register name="spr153" group="SPR_UNNAMED"/>
    <register name="spr154" group="SPR_UNNAMED"/>
    <register name="spr155" group="SPR_UNNAMED"/>
    <register name="spr156" group="SPR_UNNAMED"/>
    <register name="spr157" group="SPR_UNNAMED"/>
    <register name="spr158" group="SPR_UNNAMED"/>
    <register name="spr159" group="SPR_UNNAMED"/>
    <register name="spr15a" group="SPR_UNNAMED"/>
    <register name="spr15b" group="SPR_UNNAMED"/>
    <register name="spr15c" group="SPR_UNNAMED"/>
    <register name="spr15d" group="SPR_UNNAMED"/>
    <register name="spr15e" group="SPR_UNNAMED"/>
    <register name="spr15f" group="SPR_UNNAMED"/>
    <register name="spr160" group="SPR_UNNAMED"/>
    <register name="spr161" group="SPR_UNNAMED"/>
    <register name="spr162" group="SPR_UNNAMED"/>
    <register name="spr163" group="SPR_UNNAMED"/>
    <register name="spr164" group="SPR_UNNAMED"/>
    <register name="spr165" group="SPR_UNNAMED"/>
    <register name="spr166" group="SPR_UNNAMED"/>
    <register name="spr167" group="SPR_UNNAMED"/>
    <register name="spr168" group="SPR_UNNAMED"/>
    <register name="spr169" group="SPR_UNNAMED"/>
    <register name="spr16a" group="SPR_UNNAMED"/>
    <register name="spr16b" group="SPR_UNNAMED"/>
    <register name="spr16c" group="SPR_UNNAMED"/>
    <register name="spr16d" group="SPR_UNNAMED"/>
    <register name="spr16e" group="SPR_UNNAMED"/>
    <register name="spr16f" group="SPR_UNNAMED"/>
    <register name="spr170" group="SPR_UNNAMED"/>
    <register name="spr171" group="SPR_UNNAMED"/>
    <register name="spr172" group="SPR_UNNAMED"/>
    <register name="spr173" group="SPR_UNNAMED"/>
    <register name="spr174" group="SPR_UNNAMED"/>
    <register name="spr175" group="SPR_UNNAMED"/>
    <register name="spr176" group="SPR_UNNAMED"/>
    <register name="spr177" group="SPR_UNNAMED"/>
    <register name="spr178" group="SPR_UNNAMED"/>
    <register name="spr179" group="SPR_UNNAMED"/>
    <register name="spr17a" group="SPR_UNNAMED"/>
    <register name="spr17b" group="SPR_UNNAMED"/>
    <register name="spr17c" group="SPR_UNNAMED"/>
    <register name="spr17d" group="SPR_UNNAMED"/>
    <register name="spr17e" group="SPR_UNNAMED"/>
    <register name="spr17f" group="SPR_UNNAMED"/>
    <register name="spr180" group="SPR_UNNAMED"/>
    <register name="spr181" group="SPR_UNNAMED"/>
    <register name="spr182" group="SPR_UNNAMED"/>
    <register name="spr183" group="SPR_UNNAMED"/>
    <register name="spr184" group="SPR_UNNAMED"/>
    <register name="spr185" group="SPR_UNNAMED"/>
    <register name="spr186" group="SPR_UNNAMED"/>
    <register name="spr187" group="SPR_UNNAMED"/>
    <register name="spr188" group="SPR_UNNAMED"/>
    <register name="spr189" group="SPR_UNNAMED"/>
    <register name="spr18a" group="SPR_UNNAMED"/>
    <register name="spr18b" group="SPR_UNNAMED"/>
    <register name="spr18c" group="SPR_UNNAMED"/>
    <register name="spr18d" group="SPR_UNNAMED"/>
    <register name="spr18e" group="SPR_UNNAMED"/>
    <register name="spr18f" group="SPR_UNNAMED"/>
    <register name="spr190" rename="IVOR0" group="SPR"/>
    <register name="spr191" rename="IVOR1" group="SPR"/>
    <register name="spr192" rename="IVOR2" group="SPR"/>
    <register name="spr193" rename="IVOR3" group="SPR"/>
    <register name="spr194" rename="IVOR4" group="SPR"/>
    <register name="spr195" rename="IVOR5" group="SPR"/>
    <register name="spr196" rename="IVOR6" group="SPR"/>
    <register name="spr197" rename="IVOR7" group="SPR"/>
    <register name="spr198" rename="IVOR8" group="SPR"/>
    <register name="spr199" rename="IVOR9" group="SPR"/>
    <register name="spr19a" rename="IVOR10" group="SPR"/>
    <register name="spr19b" rename="IVOR11" group="SPR"/>
    <register name="spr19c" rename="IVOR12" group="SPR"/>
    <register name="spr19d" rename="IVOR13" group="SPR"/>
    <register name="spr19e" rename="IVOR14" group="SPR"/>
    <register name="spr19f" rename="IVOR15" group="SPR"/>
    <register name="spr1a0" group="SPR_UNNAMED"/>
    <register name="spr1a1" group="SPR_UNNAMED"/>
    <register name="spr1a2" group="SPR_UNNAMED"/>
    <register name="spr1a3" group="SPR_UNNAMED"/>
    <register name="spr1a4" group="SPR_UNNAMED"/>
    <register name="spr1a5" group="SPR_UNNAMED"/>
    <register name="spr1a6" group="SPR_UNNAMED"/>
    <register name="spr1a7" group="SPR_UNNAMED"/>
    <register name="spr1a8" group="SPR_UNNAMED"/>
    <register name="spr1a9" group="SPR_UNNAMED"/>
    <register name="spr1aa" group="SPR_UNNAMED"/>
    <register name="spr1ab" group="SPR_UNNAMED"/>
    <register name="spr1ac" group="SPR_UNNAMED"/>
    <register name="spr1ad" group="SPR_UNNAMED"/>
    <register name="spr1ae" group="SPR_UNNAMED"/>
    <register name="spr1af" group="SPR_UNNAMED"/>
    <register name="spr1b0" group="SPR_UNNAMED"/>
    <register name="spr1b1" group="SPR_UNNAMED"/>
    <register name="spr1b2" group="SPR_UNNAMED"/>
    <register name="spr1b3" group="SPR_UNNAMED"/>
    <register name="spr1b4" group="SPR_UNNAMED"/>
    <register name="spr1b5" group="SPR_UNNAMED"/>
    <register name="spr1b6" group="SPR_UNNAMED"/>
    <register name="spr1b7" group="SPR_UNNAMED"/>
    <register name="spr1b8" group="SPR_UNNAMED"/>
    <register name="spr1b9" group="SPR_UNNAMED"/>
    <register name="spr1ba" group="SPR_UNNAMED"/>
    <register name="spr1bb" group="SPR_UNNAMED"/>
    <register name="spr1bc" group="SPR_UNNAMED"/>
    <register name="spr1bd" group="SPR_UNNAMED"/>
    <register name="spr1be" group="SPR_UNNAMED"/>
    <register name="spr1bf" group="SPR_UNNAMED"/>
    <register name="spr1c0" group="SPR_UNNAMED"/>
    <register name="spr1c1" group="SPR_UNNAMED"/>
    <register name="spr1c2" group="SPR_UNNAMED"/>
    <register name="spr1c3" group="SPR_UNNAMED"/>
    <register name="spr1c4" group="SPR_UNNAMED"/>
    <register name="spr1c5" group="SPR_UNNAMED"/>
    <register name="spr1c6" group="SPR_UNNAMED"/>
    <register name="spr1c7" group="SPR_UNNAMED"/>
    <register name="spr1c8" group="SPR_UNNAMED"/>
    <register name="spr1c9" group="SPR_UNNAMED"/>
    <register name="spr1ca" group="SPR_UNNAMED"/>
    <register name="spr1cb" group="SPR_UNNAMED"/>
    <register name="spr1cc" group="SPR_UNNAMED"/>
    <register name="spr1cd" group="SPR_UNNAMED"/>
    <register name="spr1ce" group="SPR_UNNAMED"/>
    <register name="spr1cf" group="SPR_UNNAMED"/>
    <register name="spr1d0" group="SPR_UNNAMED"/>
    <register name="spr1d1" group="SPR_UNNAMED"/>
    <register name="spr1d2" group="SPR_UNNAMED"/>
    <register name="spr1d3" group="SPR_UNNAMED"/>
    <register name="spr1d4" group="SPR_UNNAMED"/>
    <register name="spr1d5" group="SPR_UNNAMED"/>
    <register name="spr1d6" group="SPR_UNNAMED"/>
    <register name="spr1d7" group="SPR_UNNAMED"/>
    <register name="spr1d8" group="SPR_UNNAMED"/>
    <register name="spr1d9" group="SPR_UNNAMED"/>
    <register name="spr1da" group="SPR_UNNAMED"/>
    <register name="spr1db" group="SPR_UNNAMED"/>
    <register name="spr1dc" group="SPR_UNNAMED"/>
    <register name="spr1dd" group="SPR_UNNAMED"/>
    <register name="spr1de" group="SPR_UNNAMED"/>
    <register name="spr1df" group="SPR_UNNAMED"/>
    <register name="spr1e0" group="SPR_UNNAMED"/>
    <register name="spr1e1" group="SPR_UNNAMED"/>
    <register name="spr1e2" group="SPR_UNNAMED"/>
    <register name="spr1e3" group="SPR_UNNAMED"/>
    <register name="spr1e4" group="SPR_UNNAMED"/>
    <register name="spr1e5" group="SPR_UNNAMED"/>
    <register name="spr1e6" group="SPR_UNNAMED"/>
    <register name="spr1e7" group="SPR_UNNAMED"/>
    <register name="spr1e8" group="SPR_UNNAMED"/>
    <register name="spr1e9" group="SPR_UNNAMED"/>
    <register name="spr1ea" group="SPR_UNNAMED"/>
    <register name="spr1eb" group="SPR_UNNAMED"/>
    <register name="spr1ec" group="SPR_UNNAMED"/>
    <register name="spr1ed" group="SPR_UNNAMED"/>
    <register name="spr1ee" group="SPR_UNNAMED"/>
    <register name="spr1ef" group="SPR_UNNAMED"/>
    <register name="spr1f0" group="SPR_UNNAMED"/>
    <register name="spr1f1" group="SPR_UNNAMED"/>
    <register name="spr1f2" group="SPR_UNNAMED"/>
    <register name="spr1f3" group="SPR_UNNAMED"/>
    <register name="spr1f4" group="SPR_UNNAMED"/>
    <register name="spr1f5" group="SPR_UNNAMED"/>
    <register name="spr1f6" group="SPR_UNNAMED"/>
    <register name="spr1f7" group="SPR_UNNAMED"/>
    <register name="spr1f8" group="SPR_UNNAMED"/>
    <register name="spr1f9" group="SPR_UNNAMED"/>
    <register name="spr1fa" group="SPR_UNNAMED"/>
    <register name="spr1fb" group="SPR_UNNAMED"/>
    <register name="spr1fc" group="SPR_UNNAMED"/>
    <register name="spr1fd" group="SPR_UNNAMED"/>
    <register name="spr1fe" group="SPR_UNNAMED"/>
    <register name="spr1ff" group="SPR_UNNAMED"/>
    <register name="spr200" group="SPR_UNNAMED"/>
    <register name="spr201" group="SPR_UNNAMED"/>
    <register name="spr202" group="SPR_UNNAMED"/>
    <register name="spr203" group="SPR_UNNAMED"/>
    <register name="spr204" group="SPR_UNNAMED"/>
    <register name="spr205" group="SPR_UNNAMED"/>
    <register name="spr206" group="SPR_UNNAMED"/>
    <register name="spr207" group="SPR_UNNAMED"/>
    <register name="spr208" group="SPR_UNNAMED"/>
    <register name="spr209" group="SPR_UNNAMED"/>
    <register name="spr20a" group="SPR_UNNAMED"/>
    <register name="spr20b" group="SPR_UNNAMED"/>
    <register name="spr20c" group="SPR_UNNAMED"/>
    <register name="spr20d" group="SPR_UNNAMED"/>
    <register name="spr20e" group="SPR_UNNAMED"/>
    <register name="spr20f" group="SPR_UNNAMED"/>
    <register name="spr210" rename="IBAT0U" group="SPR"/>
    <register name="spr211" rename="IBAT0L" group="SPR"/>
    <register name="spr212" rename="IBAT1U" group="SPR"/>
    <register name="spr213" rename="IBAT1L" group="SPR"/>
    <register name="spr214" rename="IBAT2U" group="SPR"/>
    <register name="spr215" rename="IBAT2L" group="SPR"/>
    <register name="spr216" rename="IBAT3U" group="SPR"/>
    <register name="spr217" rename="IBAT3L" group="SPR"/>
    <register name="spr218" rename="DBAT0U" group="SPR"/>
    <register name="spr219" rename="DBAT0L" group="SPR"/>
    <register name="spr21a" rename="DBAT1U" group="SPR"/>
    <register name="spr21b" rename="DBAT1L" group="SPR"/>
    <register name="spr21c" rename="DBAT2U" group="SPR"/>
    <register name="spr21d" rename="DBAT2L" group="SPR"/>
    <register name="spr21e" rename="DBAT3U" group="SPR"/>
    <register name="spr21f" rename="DBAT3L" group="SPR"/>
    <register name="spr220" group="SPR_UNNAMED"/>
    <register name="spr221" group="SPR_UNNAMED"/>
    <register name="spr222" group="SPR_UNNAMED"/>
    <register name="spr223" group="SPR_UNNAMED"/>
    <register name="spr224" group="SPR_UNNAMED"/>
    <register name="spr225" group="SPR_UNNAMED"/>
    <register name="spr226" group="SPR_UNNAMED"/>
    <register name="spr227" group="SPR_UNNAMED"/>
    <register name="spr228" group="SPR_UNNAMED"/>
    <register name="spr229" group="SPR_UNNAMED"/>
    <register name="spr22a" group="SPR_UNNAMED"/>
    <register name="spr22b" group="SPR_UNNAMED"/>
    <register name="spr22c" group="SPR_UNNAMED"/>
    <register name="spr22d" group="SPR_UNNAMED"/>
    <register name="spr22e" group="SPR_UNNAMED"/>
    <register name="spr22f" group="SPR_UNNAMED"/>
    <register name="spr230" rename="IC_CSR" group="SPR"/>
    <register name="spr231" rename="IC_ADR" group="SPR"/>
    <register name="spr232" rename="IC_DAT" group="SPR"/>
    <register name="spr233" group="SPR_UNNAMED"/>
    <register name="spr234" group="SPR_UNNAMED"/>
    <register name="spr235" group="SPR_UNNAMED"/>
    <register name="spr236" group="SPR_UNNAMED"/>
    <register name="spr237" group="SPR_UNNAMED"/>
    <register name="spr238" rename="DC_CST" group="SPR"/>
    <register name="spr239" rename="DC_ADR" group="SPR"/>
    <register name="spr23a" rename="DC_DAT" group="SPR"/>
    <register name="spr23b" group="SPR_UNNAMED"/>
    <register name="spr23c" group="SPR_UNNAMED"/>
    <register name="spr23d" group="SPR_UNNAMED"/>
    <register name="spr23e" group="SPR_UNNAMED"/>
    <register name="spr23f" group="SPR_UNNAMED"/>
    <register name="spr240" group="SPR_UNNAMED"/>
    <register name="spr241" group="SPR_UNNAMED"/>
    <register name="spr242" group="SPR_UNNAMED"/>
    <register name="spr243" group="SPR_UNNAMED"/>
    <register name="spr244" group="SPR_UNNAMED"/>
    <register name="spr245" group="SPR_UNNAMED"/>
    <register name="spr246" group="SPR_UNNAMED"/>
    <register name="spr247" group="SPR_UNNAMED"/>
    <register name="spr248" group="SPR_UNNAMED"/>
    <register name="spr249" group="SPR_UNNAMED"/>
    <register name="spr24a" group="SPR_UNNAMED"/>
    <register name="spr24b" group="SPR_UNNAMED"/>
    <register name="spr24c" group="SPR_UNNAMED"/>
    <register name="spr24d" group="SPR_UNNAMED"/>
    <register name="spr24e" group="SPR_UNNAMED"/>
    <register name="spr24f" group="SPR_UNNAMED"/>
    <register name="spr250" group="SPR_UNNAMED"/>
    <register name="spr251" group="SPR_UNNAMED"/>
    <register name="spr252" group="SPR_UNNAMED"/>
    <register name="spr253" group="SPR_UNNAMED"/>
    <register name="spr254" group="SPR_UNNAMED"/>
    <register name="spr255" group="SPR_UNNAMED"/>
    <register name="spr256" group="SPR_UNNAMED"/>
    <register name="spr257" group="SPR_UNNAMED"/>
    <register name="spr258" group="SPR_UNNAMED"/>
    <register name="spr259" group="SPR_UNNAMED"/>
    <register name="spr25a" group="SPR_UNNAMED"/>
    <register name="spr25b" group="SPR_UNNAMED"/>
    <register name="spr25c" group="SPR_UNNAMED"/>
    <register name="spr25d" group="SPR_UNNAMED"/>
    <register name="spr25e" group="SPR_UNNAMED"/>
    <register name="spr25f" group="SPR_UNNAMED"/>
    <register name="spr260" group="SPR_UNNAMED"/>
    <register name="spr261" group="SPR_UNNAMED"/>
    <register name="spr262" group="SPR_UNNAMED"/>
    <register name="spr263" group="SPR_UNNAMED"/>
    <register name="spr264" group="SPR_UNNAMED"/>
    <register name="spr265" group="SPR_UNNAMED"/>
    <register name="spr266" group="SPR_UNNAMED"/>
    <register name="spr267" group="SPR_UNNAMED"/>
    <register name="spr268" group="SPR_UNNAMED"/>
    <register name="spr269" group="SPR_UNNAMED"/>
    <register name="spr26a" group="SPR_UNNAMED"/>
    <register name="spr26b" group="SPR_UNNAMED"/>
    <register name="spr26c" group="SPR_UNNAMED"/>
    <register name="spr26d" group="SPR_UNNAMED"/>
    <register name="spr26e" group="SPR_UNNAMED"/>
    <register name="spr26f" group="SPR_UNNAMED"/>
    <register name="spr270" group="SPR_UNNAMED"/>
    <register name="spr271" group="SPR_UNNAMED"/>
    <register name="spr272" group="SPR_UNNAMED"/>
    <register name="spr273" group="SPR_UNNAMED"/>
    <register name="spr274" group="SPR_UNNAMED"/>
    <register name="spr275" group="SPR_UNNAMED"/>
    <register name="spr276" rename="DPDR" group="SPR"/>
    <register name="spr277" rename="DPIR" group="SPR"/>
    <register name="spr278" group="SPR_UNNAMED"/>
    <register name="spr279" group="SPR_UNNAMED"/>
    <register name="spr27a" group="SPR_UNNAMED"/>
    <register name="spr27b" group="SPR_UNNAMED"/>
    <register name="spr27c" group="SPR_UNNAMED"/>
    <register name="spr27d" group="SPR_UNNAMED"/>
    <register name="spr27e" rename="IMMR" group="SPR"/>
    <register name="spr27f" group="SPR_UNNAMED"/>
    <register name="spr280" group="SPR_UNNAMED"/>
    <register name="spr281" group="SPR_UNNAMED"/>
    <register name="spr282" group="SPR_UNNAMED"/>
    <register name="spr283" group="SPR_UNNAMED"/>
    <register name="spr284" group="SPR_UNNAMED"/>
    <register name="spr285" group="SPR_UNNAMED"/>
    <register name="spr286" group="SPR_UNNAMED"/>
    <register name="spr287" group="SPR_UNNAMED"/>
    <register name="spr288" group="SPR_UNNAMED"/>
    <register name="spr289" group="SPR_UNNAMED"/>
    <register name="spr28a" group="SPR_UNNAMED"/>
    <register name="spr28b" group="SPR_UNNAMED"/>
    <register name="spr28c" group="SPR_UNNAMED"/>
    <register name="spr28d" group="SPR_UNNAMED"/>
    <register name="spr28e" group="SPR_UNNAMED"/>
    <register name="spr28f" group="SPR_UNNAMED"/>
    <register name="spr290" group="SPR_UNNAMED"/>
    <register name="spr291" group="SPR_UNNAMED"/>
    <register name="spr292" group="SPR_UNNAMED"/>
    <register name="spr293" group="SPR_UNNAMED"/>
    <register name="spr294" group="SPR_UNNAMED"/>
    <register name="spr295" group="SPR_UNNAMED"/>
    <register name="spr296" group="SPR_UNNAMED"/>
    <register name="spr297" group="SPR_UNNAMED"/>
    <register name="spr298" group="SPR_UNNAMED"/>
    <register name="spr299" group="SPR_UNNAMED"/>
    <register name="spr29a" group="SPR_UNNAMED"/>
    <register name="spr29b" group="SPR_UNNAMED"/>
    <register name="spr29c" group="SPR_UNNAMED"/>
    <register name="spr29d" group="SPR_UNNAMED"/>
    <register name="spr29e" group="SPR_UNNAMED"/>
    <register name="spr29f" group="SPR_UNNAMED"/>
    <register name="spr2a0" group="SPR_UNNAMED"/>
    <register name="spr2a1" group="SPR_UNNAMED"/>
    <register name="spr2a2" group="SPR_UNNAMED"/>
    <register name="spr2a3" group="SPR_UNNAMED"/>
    <register name="spr2a4" group="SPR_UNNAMED"/>
    <register name="spr2a5" group="SPR_UNNAMED"/>
    <register name="spr2a6" group="SPR_UNNAMED"/>
    <register name="spr2a7" group="SPR_UNNAMED"/>
    <register name="spr2a8" group="SPR_UNNAMED"/>
    <register name="spr2a9" group="SPR_UNNAMED"/>
    <register name="spr2aa" group="SPR_UNNAMED"/>
    <register name="spr2ab" group="SPR_UNNAMED"/>
    <register name="spr2ac" group="SPR_UNNAMED"/>
    <register name="spr2ad" group="SPR_UNNAMED"/>
    <register name="spr2ae" group="SPR_UNNAMED"/>
    <register name="spr2af" group="SPR_UNNAMED"/>
    <register name="spr2b0" group="SPR_UNNAMED"/>
    <register name="spr2b1" group="SPR_UNNAMED"/>
    <register name="spr2b2" group="SPR_UNNAMED"/>
    <register name="spr2b3" group="SPR_UNNAMED"/>
    <register name="spr2b4" group="SPR_UNNAMED"/>
    <register name="spr2b5" group="SPR_UNNAMED"/>
    <register name="spr2b6" group="SPR_UNNAMED"/>
    <register name="spr2b7" group="SPR_UNNAMED"/>
    <register name="spr2b8" group="SPR_UNNAMED"/>
    <register name="spr2b9" group="SPR_UNNAMED"/>
    <register name="spr2ba" group="SPR_UNNAMED"/>
    <register name="spr2bb" group="SPR_UNNAMED"/>
    <register name="spr2bc" group="SPR_UNNAMED"/>
    <register name="spr2bd" group="SPR_UNNAMED"/>
    <register name="spr2be" group="SPR_UNNAMED"/>
    <register name="spr2bf" group="SPR_UNNAMED"/>
    <register name="spr2c0" group="SPR_UNNAMED"/>
    <register name="spr2c1" group="SPR_UNNAMED"/>
    <register name="spr2c2" group="SPR_UNNAMED"/>
    <register name="spr2c3" group="SPR_UNNAMED"/>
    <register name="spr2c4" group="SPR_UNNAMED"/>
    <register name="spr2c5" group="SPR_UNNAMED"/>
    <register name="spr2c6" group="SPR_UNNAMED"/>
    <register name="spr2c7" group="SPR_UNNAMED"/>
    <register name="spr2c8" group="SPR_UNNAMED"/>
    <register name="spr2c9" group="SPR_UNNAMED"/>
    <register name="spr2ca" group="SPR_UNNAMED"/>
    <register name="spr2cb" group="SPR_UNNAMED"/>
    <register name="spr2cc" group="SPR_UNNAMED"/>
    <register name="spr2cd" group="SPR_UNNAMED"/>
    <register name="spr2ce" group="SPR_UNNAMED"/>
    <register name="spr2cf" group="SPR_UNNAMED"/>
    <register name="spr2d0" group="SPR_UNNAMED"/>
    <register name="spr2d1" group="SPR_UNNAMED"/>
    <register name="spr2d2" group="SPR_UNNAMED"/>
    <register name="spr2d3" group="SPR_UNNAMED"/>
    <register name="spr2d4" group="SPR_UNNAMED"/>
    <register name="spr2d5" group="SPR_UNNAMED"/>
    <register name="spr2d6" group="SPR_UNNAMED"/>
    <register name="spr2d7" group="SPR_UNNAMED"/>
    <register name="spr2d8" group="SPR_UNNAMED"/>
    <register name="spr2d9" group="SPR_UNNAMED"/>
    <register name="spr2da" group="SPR_UNNAMED"/>
    <register name="spr2db" group="SPR_UNNAMED"/>
    <register name="spr2dc" group="SPR_UNNAMED"/>
    <register name="spr2dd" group="SPR_UNNAMED"/>
    <register name="spr2de" group="SPR_UNNAMED"/>
    <register name="spr2df" group="SPR_UNNAMED"/>
    <register name="spr2e0" group="SPR_UNNAMED"/>
    <register name="spr2e1" group="SPR_UNNAMED"/>
    <register name="spr2e2" group="SPR_UNNAMED"/>
    <register name="spr2e3" group="SPR_UNNAMED"/>
    <register name="spr2e4" group="SPR_UNNAMED"/>
    <register name="spr2e5" group="SPR_UNNAMED"/>
    <register name="spr2e6" group="SPR_UNNAMED"/>
    <register name="spr2e7" group="SPR_UNNAMED"/>
    <register name="spr2e8" group="SPR_UNNAMED"/>
    <register name="spr2e9" group="SPR_UNNAMED"/>
    <register name="spr2ea" group="SPR_UNNAMED"/>
    <register name="spr2eb" group="SPR_UNNAMED"/>
    <register name="spr2ec" group="SPR_UNNAMED"/>
    <register name="spr2ed" group="SPR_UNNAMED"/>
    <register name="spr2ee" group="SPR_UNNAMED"/>
    <register name="spr2ef" group="SPR_UNNAMED"/>
    <register name="spr2f0" group="SPR_UNNAMED"/>
    <register name="spr2f1" group="SPR_UNNAMED"/>
    <register name="spr2f2" group="SPR_UNNAMED"/>
    <register name="spr2f3" group="SPR_UNNAMED"/>
    <register name="spr2f4" group="SPR_UNNAMED"/>
    <register name="spr2f5" group="SPR_UNNAMED"/>
    <register name="spr2f6" group="SPR_UNNAMED"/>
    <register name="spr2f7" group="SPR_UNNAMED"/>
    <register name="spr2f8" group="SPR_UNNAMED"/>
    <register name="spr2f9" group="SPR_UNNAMED"/>
    <register name="spr2fa" group="SPR_UNNAMED"/>
    <register name="spr2fb" group="SPR_UNNAMED"/>
    <register name="spr2fc" group="SPR_UNNAMED"/>
    <register name="spr2fd" group="SPR_UNNAMED"/>
    <register name="spr2fe" group="SPR_UNNAMED"/>
    <register name="spr2ff" group="SPR_UNNAMED"/>
    <register name="spr300" group="SPR_UNNAMED"/>
    <register name="spr301" group="SPR_UNNAMED"/>
    <register name="spr302" group="SPR_UNNAMED"/>
    <register name="spr303" group="SPR_UNNAMED"/>
    <register name="spr304" group="SPR_UNNAMED"/>
    <register name="spr305" group="SPR_UNNAMED"/>
    <register name="spr306" group="SPR_UNNAMED"/>
    <register name="spr307" group="SPR_UNNAMED"/>
    <register name="spr308" group="SPR_UNNAMED"/>
    <register name="spr309" group="SPR_UNNAMED"/>
    <register name="spr30a" rename="SIA" group="SPR"/>
    <register name="spr30b" rename="SDA" group="SPR"/>
    <register name="spr30c" group="SPR_UNNAMED"/>
    <register name="spr30d" group="SPR_UNNAMED"/>
    <register name="spr30e" group="SPR_UNNAMED"/>
    <register name="spr30f" group="SPR_UNNAMED"/>
    <register name="spr310" rename="MI_CTR" group="SPR"/>
    <register name="spr311" group="SPR_UNNAMED"/>
    <register name="spr312" rename="MI_AP" group="SPR"/>
    <register name="spr313" rename="MI_EPN" group="SPR"/>
    <register name="spr314" group="SPR_UNNAMED"/>
    <register name="spr315" rename="MI_TWC" group="SPR"/>
    <register name="spr316" rename="MI_RPN" group="SPR"/>
    <register name="spr317" group="SPR_UNNAMED"/>
    <register name="spr318" rename="MD_CTR" group="SPR"/>
    <register name="spr319" rename="M_CASID" group="SPR"/>
    <register name="spr31a" rename="MD_AP" group="SPR"/>
    <register name="spr31b" rename="MD_EPN" group="SPR"/>
    <register name="spr31c" rename="M_TWB" group="SPR"/>
    <register name="spr31d" rename="M_TWC" group="SPR"/>
    <register name="spr31e" rename="MD_RPN" group="SPR"/>
    <register name="spr31f" rename="N_TW" group="SPR"/>
    <register name="spr320" group="SPR_UNNAMED"/>
    <register name="spr321" group="SPR_UNNAMED"/>
    <register name="spr322" group="SPR_UNNAMED"/>
    <register name="spr323" group="SPR_UNNAMED"/>
    <register name="spr324" group="SPR_UNNAMED"/>
    <register name="spr325" group="SPR_UNNAMED"/>
    <register name="spr326" group="SPR_UNNAMED"/>
    <register name="spr327" group="SPR_UNNAMED"/>
    <register name="spr328" group="SPR_UNNAMED"/>
    <register name="spr329" group="SPR_UNNAMED"/>
    <register name="spr32a" group="SPR_UNNAMED"/>
    <register name="spr32b" group="SPR_UNNAMED"/>
    <register name="spr32c" group="SPR_UNNAMED"/>
    <register name="spr32d" group="SPR_UNNAMED"/>
    <register name="spr32e" group="SPR_UNNAMED"/>
    <register name="TAR" group="SPR"/>
    <register name="spr330" rename="MI_CAM" group="SPR"/>
    <register name="spr331" rename="MIram0" group="SPR"/>
    <register name="spr332" rename="MIram1" group="SPR"/>
    <register name="spr333" group="SPR_UNNAMED"/>
    <register name="spr334" group="SPR_UNNAMED"/>
    <register name="spr335" group="SPR_UNNAMED"/>
    <register name="spr336" group="SPR_UNNAMED"/>
    <register name="spr337" group="SPR_UNNAMED"/>
    <register name="spr338" rename="MD_CAM" group="SPR"/>
    <register name="spr339" rename="MDram0" group="SPR"/>
    <register name="spr33a" rename="MDram1" group="SPR"/>
    <register name="spr33b" group="SPR_UNNAMED"/>
    <register name="spr33c" group="SPR_UNNAMED"/>
    <register name="spr33d" group="SPR_UNNAMED"/>
    <register name="spr33e" group="SPR_UNNAMED"/>
    <register name="spr33f" group="SPR_UNNAMED"/>
    <register name="spr340" group="SPR_UNNAMED"/>
    <register name="spr341" group="SPR_UNNAMED"/>
    <register name="spr342" group="SPR_UNNAMED"/>
    <register name="spr343" group="SPR_UNNAMED"/>
    <register name="spr344" group="SPR_UNNAMED"/>
    <register name="spr345" group="SPR_UNNAMED"/>
    <register name="spr346" group="SPR_UNNAMED"/>
    <register name="spr347" group="SPR_UNNAMED"/>
    <register name="spr348" group="SPR_UNNAMED"/>
    <register name="spr349" group="SPR_UNNAMED"/>
    <register name="spr34a" group="SPR_UNNAMED"/>
    <register name="spr34b" group="SPR_UNNAMED"/>
    <register name="spr34c" group="SPR_UNNAMED"/>
    <register name="spr34d" group="SPR_UNNAMED"/>
    <register name="spr34e" group="SPR_UNNAMED"/>
    <register name="spr34f" group="SPR_UNNAMED"/>
    <register name="spr350" group="SPR_UNNAMED"/>
    <register name="spr351" group="SPR_UNNAMED"/>
    <register name="spr352" group="SPR_UNNAMED"/>
    <register name="spr353" group="SPR_UNNAMED"/>
    <register name="spr354" group="SPR_UNNAMED"/>
    <register name="spr355" group="SPR_UNNAMED"/>
    <register name="spr356" group="SPR_UNNAMED"/>
    <register name="spr357" group="SPR_UNNAMED"/>
    <register name="spr358" group="SPR_UNNAMED"/>
    <register name="spr359" group="SPR_UNNAMED"/>
    <register name="spr35a" group="SPR_UNNAMED"/>
    <register name="spr35b" group="SPR_UNNAMED"/>
    <register name="spr35c" group="SPR_UNNAMED"/>
    <register name="spr35d" group="SPR_UNNAMED"/>
    <register name="spr35e" group="SPR_UNNAMED"/>
    <register name="spr35f" group="SPR_UNNAMED"/>
    <register name="spr360" group="SPR_UNNAMED"/>
    <register name="spr361" group="SPR_UNNAMED"/>
    <register name="spr362" group="SPR_UNNAMED"/>
    <register name="spr363" group="SPR_UNNAMED"/>
    <register name="spr364" group="SPR_UNNAMED"/>
    <register name="spr365" group="SPR_UNNAMED"/>
    <register name="spr366" group="SPR_UNNAMED"/>
    <register name="spr367" group="SPR_UNNAMED"/>
    <register name="spr368" group="SPR_UNNAMED"/>
    <register name="spr369" group="SPR_UNNAMED"/>
    <register name="spr36a" group="SPR_UNNAMED"/>
    <register name="spr36b" group="SPR_UNNAMED"/>
    <register name="spr36c" group="SPR_UNNAMED"/>
    <register name="spr36d" group="SPR_UNNAMED"/>
    <register name="spr36e" group="SPR_UNNAMED"/>
    <register name="spr36f" group="SPR_UNNAMED"/>
    <register name="spr370" group="SPR_UNNAMED"/>
    <register name="spr371" group="SPR_UNNAMED"/>
    <register name="spr372" group="SPR_UNNAMED"/>
    <register name="spr373" group="SPR_UNNAMED"/>
    <register name="spr374" group="SPR_UNNAMED"/>
    <register name="spr375" group="SPR_UNNAMED"/>
    <register name="spr376" group="SPR_UNNAMED"/>
    <register name="spr377" group="SPR_UNNAMED"/>
    <register name="spr378" group="SPR_UNNAMED"/>
    <register name="spr379" group="SPR_UNNAMED"/>
    <register name="spr37a" group="SPR_UNNAMED"/>
    <register name="spr37b" group="SPR_UNNAMED"/>
    <register name="spr37c" group="SPR_UNNAMED"/>
    <register name="spr37d" group="SPR_UNNAMED"/>
    <register name="spr37e" group="SPR_UNNAMED"/>
    <register name="spr37f" group="SPR_UNNAMED"/>
    <register name="spr380" group="SPR_UNNAMED"/>
    <register name="spr381" group="SPR_UNNAMED"/>
    <register name="spr382" group="SPR_UNNAMED"/>
    <register name="spr383" group="SPR_UNNAMED"/>
    <register name="spr384" group="SPR_UNNAMED"/>
    <register name="spr385" group="SPR_UNNAMED"/>
    <register name="spr386" group="SPR_UNNAMED"/>
    <register name="spr387" group="SPR_UNNAMED"/>
    <register name="spr388" group="SPR_UNNAMED"/>
    <register name="spr389" group="SPR_UNNAMED"/>
    <register name="spr38a" group="SPR_UNNAMED"/>
    <register name="spr38b" group="SPR_UNNAMED"/>
    <register name="spr38c" group="SPR_UNNAMED"/>
    <register name="spr38d" group="SPR_UNNAMED"/>
    <register name="spr38e" group="SPR_UNNAMED"/>
    <register name="spr38f" group="SPR_UNNAMED"/>
    <register name="spr390" group="SPR_UNNAMED"/>
    <register name="spr391" group="SPR_UNNAMED"/>
    <register name="spr392" group="SPR_UNNAMED"/>
    <register name="spr393" group="SPR_UNNAMED"/>
    <register name="spr394" group="SPR_UNNAMED"/>
    <register name="spr395" group="SPR_UNNAMED"/>
    <register name="spr396" group="SPR_UNNAMED"/>
    <register name="spr397" group="SPR_UNNAMED"/>
    <register name="spr398" group="SPR_UNNAMED"/>
    <register name="spr399" group="SPR_UNNAMED"/>
    <register name="spr39a" group="SPR_UNNAMED"/>
    <register name="spr39b" group="SPR_UNNAMED"/>
    <register name="spr39c" group="SPR_UNNAMED"/>
    <register name="spr39d" group="SPR_UNNAMED"/>
    <register name="spr39e" group="SPR_UNNAMED"/>
    <register name="spr39f" group="SPR_UNNAMED"/>
    <register name="spr3a0" group="SPR_UNNAMED"/>
    <register name="spr3a1" group="SPR_UNNAMED"/>
    <register name="spr3a2" group="SPR_UNNAMED"/>
    <register name="spr3a3" group="SPR_UNNAMED"/>
    <register name="spr3a4" group="SPR_UNNAMED"/>
    <register name="spr3a5" group="SPR_UNNAMED"/>
    <register name="spr3a6" group="SPR_UNNAMED"/>
    <register name="spr3a7" group="SPR_UNNAMED"/>
    <register name="spr3a8" group="SPR_UNNAMED"/>
    <register name="spr3a9" group="SPR_UNNAMED"/>
    <register name="spr3aa" group="SPR_UNNAMED"/>
    <register name="spr3ab" group="SPR_UNNAMED"/>
    <register name="spr3ac" group="SPR_UNNAMED"/>
    <register name="spr3ad" group="SPR_UNNAMED"/>
    <register name="spr3ae" group="SPR_UNNAMED"/>
    <register name="spr3af" group="SPR_UNNAMED"/>
    <register name="spr3b0" rename="ZPR" group="SPR"/>
    <register name="spr3b1" rename="PID" group="SPR"/>
    <register name="spr3b2" group="SPR_UNNAMED"/>
    <register name="spr3b3" rename="CCR0" group="SPR"/>
    <register name="spr3b4" rename="IAC3" group="SPR"/>
    <register name="spr3b5" rename="IAC4" group="SPR"/>
    <register name="spr3b6" rename="DVC1" group="SPR"/>
    <register name="spr3b7" rename="DVC2" group="SPR"/>
    <register name="spr3b8" rename="SMR" group="SPR"/>
    <register name="spr3b9" rename="SGR" group="SPR"/>
    <register name="spr3ba" rename="DCWR" group="SPR"/>
    <register name="spr3bb" rename="SLER" group="SPR"/>
    <register name="spr3bc" rename="SUOR" group="SPR"/>
    <register name="spr3bd" rename="DBCR1" group="SPR"/>
    <register name="spr3be" group="SPR_UNNAMED"/>
    <register name="spr3bf" group="SPR_UNNAMED"/>
    <register name="spr3c0" group="SPR_UNNAMED"/>
    <register name="spr3c1" group="SPR_UNNAMED"/>
    <register name="spr3c2" group="SPR_UNNAMED"/>
    <register name="spr3c3" group="SPR_UNNAMED"/>
    <register name="spr3c4" group="SPR_UNNAMED"/>
    <register name="spr3c5" group="SPR_UNNAMED"/>
    <register name="spr3c6" group="SPR_UNNAMED"/>
    <register name="spr3c7" group="SPR_UNNAMED"/>
    <register name="spr3c8" group="SPR_UNNAMED"/>
    <register name="spr3c9" group="SPR_UNNAMED"/>
    <register name="spr3ca" group="SPR_UNNAMED"/>
    <register name="spr3cb" group="SPR_UNNAMED"/>
    <register name="spr3cc" group="SPR_UNNAMED"/>
    <register name="spr3cd" group="SPR_UNNAMED"/>
    <register name="spr3ce" group="SPR_UNNAMED"/>
    <register name="spr3cf" group="SPR_UNNAMED"/>
    <register name="spr3d0" group="SPR_UNNAMED"/>
    <register name="spr3d1" group="SPR_UNNAMED"/>
    <register name="spr3d2" group="SPR_UNNAMED"/>
    <register name="spr3d3" rename="ICDBDR" group="SPR"/>
    <register name="spr3d4" rename="ESR" group="SPR"/>
    <register name="spr3d5" rename="DEAR" group="SPR"/>
    <register name="spr3d6" rename="EVPR" group="SPR"/>
    <register name="spr3d7" rename="CDBCR" group="SPR"/>
    <register name="spr3d8" rename="TSR" group="SPR"/>
    <register name="spr3d9" group="SPR_UNNAMED"/>
    <register name="spr3da" rename="TCR" group="SPR"/>
    <register name="spr3db" rename="PIT" group="SPR"/>
    <register name="spr3dc" rename="TBHI" group="SPR"/>
    <register name="spr3dd" rename="TBLO" group="SPR"/>
    <register name="spr3de" rename="SRR2" group="SPR"/>
    <register name="spr3df" rename="SRR3" group="SPR"/>
    <register name="spr3e0" group="SPR_UNNAMED"/>
    <register name="spr3e1" group="SPR_UNNAMED"/>
    <register name="spr3e2" group="SPR_UNNAMED"/>
    <register name="spr3e3" group="SPR_UNNAMED"/>
    <register name="spr3e4" group="SPR_UNNAMED"/>
    <register name="spr3e5" group="SPR_UNNAMED"/>
    <register name="spr3e6" group="SPR_UNNAMED"/>
    <register name="spr3e7" group="SPR_UNNAMED"/>
    <register name="spr3e8" group="SPR_UNNAMED"/>
    <register name="spr3e9" group="SPR_UNNAMED"/>
    <register name="spr3ea" group="SPR_UNNAMED"/>
    <register name="spr3eb" group="SPR_UNNAMED"/>
    <register name="spr3ec" group="SPR_UNNAMED"/>
    <register name="spr3ed" group="SPR_UNNAMED"/>
    <register name="spr3ee" group="SPR_UNNAMED"/>
    <register name="spr3ef" group="SPR_UNNAMED"/>
    <register name="spr3f0" rename="DBSR" group="SPR"/>
    <register name="spr3f1" group="SPR_UNNAMED"/>
    <register name="spr3f2" rename="DBCR0" group="SPR"/>
    <register name="spr3f3" group="SPR_UNNAMED"/>
    <register name="spr3f4" rename="IAC1" group="SPR"/>
    <register name="spr3f5" rename="IAC2" group="SPR"/>
    <register name="spr3f6" rename="DAC1" group="SPR"/>
    <register name="spr3f7" rename="DAC2" group="SPR"/>
    <register name="spr3f8" rename="BUSCSR" group="SPR"/>
    <register name="spr3f9" group="SPR_UNNAMED"/>
    <register name="spr3fa" rename="DCCR" group="SPR"/>
    <register name="spr3fb" rename="ICCR" group="SPR"/>
    <register name="spr3fc" rename="PBL1" group="SPR"/>
    <register name="spr3fd" rename="PBU1" group="SPR"/>
    <register name="spr3fe" rename="FPECR" group="SPR"/>
    <register name="spr3ff" rename="PIR" group="SPR"/>
    <register name="dcr090" rename="BEAR" group="DCR"/>
    <register name="dcr091" rename="BESR" group="DCR"/>
    <register name="dcr080" rename="BR0" group="DCR"/>
    <register name="dcr081" rename="BR1" group="DCR"/>
    <register name="dcr082" rename="BR2" group="DCR"/>
    <register name="dcr083" rename="BR3" group="DCR"/>
    <register name="dcr084" rename="BR4" group="DCR"/>
    <register name="dcr085" rename="BR5" group="DCR"/>
    <register name="dcr086" rename="BR6" group="DCR"/>
    <register name="dcr087" rename="BR7" group="DCR"/>
    <register name="dcr0c4" rename="DMACC0" group="DCR"/>
    <register name="dcr0cc" rename="DMACC1" group="DCR"/>
    <register name="dcr0d4" rename="DMACC2" group="DCR"/>
    <register name="dcr0dc" rename="DMACC3" group="DCR"/>
    <register name="dcr0c0" rename="DMACR0" group="DCR"/>
    <register name="dcr0c8" rename="DMACR1" group="DCR"/>
    <register name="dcr0d0" rename="DMACR2" group="DCR"/>
    <register name="dcr0d8" rename="DMACR3" group="DCR"/>
    <register name="dcr0c1" rename="DMACT0" group="DCR"/>
    <register name="dcr0c9" rename="DMACT1" group="DCR"/>
    <register name="dcr0d1" rename="DMACT2" group="DCR"/>
    <register name="dcr0d9" rename="DMACT3" group="DCR"/>
    <register name="dcr0c2" rename="DMADA0" group="DCR"/>
    <register name="dcr0ca" rename="DMADA1" group="DCR"/>
    <register name="dcr0d2" rename="DMADA2" group="DCR"/>
    <register name="dcr0da" rename="DMADA3" group="DCR"/>
    <register name="dcr0c3" rename="DMASA0" group="DCR"/>
    <register name="dcr0cb" rename="DMASA1" group="DCR"/>
    <register name="dcr0d3" rename="DMASA2" group="DCR"/>
    <register name="dcr0db" rename="DMASA3" group="DCR"/>
    <register name="dcr0e0" rename="DMASR" group="DCR"/>
    <register name="dcr042" rename="EXIER" group="DCR"/>
    <register name="dcr040" rename="EXISR" group="DCR"/>
    <register name="dcr0a0" rename="IOCR" group="DCR"/>
    <register name="vs0" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs1" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs2" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs3" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs4" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs5" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs6" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs7" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs8" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs9" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs10" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs11" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs12" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs13" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs14" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs15" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs16" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs17" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs18" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs19" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs20" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs21" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs22" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs23" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs24" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs25" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs26" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs27" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs28" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs29" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs30" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs31" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs32" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs33" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs34" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs35" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs36" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs37" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs38" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs39" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs40" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs41" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs42" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs43" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs44" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs45" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs46" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs47" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs48" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs49" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs50" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs51" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs52" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs53" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs54" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs55" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs56" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs57" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs58" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs59" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs60" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs61" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs62" group = "VSX" vector_lane_sizes="1,2,4"/>
    <register name="vs63" group = "VSX" vector_lane_sizes="1,2,4"/>
    </register_data>
    </processor_spec>
    What is it good for? Can you tell me more about it? Can I use it to save my bricked MSS60?
      It's one of those things where if you have to ask it's probably not useful for you. But basically it should allow you to disassemble MSS6x code more easily using the Ghidra disassembler
        Thank you.. so for the pro´s
