DIY: E9X M3 GTS DCT Flash
  • derbo
    I noticed my notes I have another ZUSB number: 7848442 as a newer one than the 773.
  • tdott
    That's awesome, thanks for posting!
  • IamFODI
    Thanks! Adding this to the DIY sticky.
  • 1984M3
    started a topic DIY: E9X M3 GTS DCT Flash
    Thought someone may find this helpful if they are interested. Just did this on my E92.
    ****Reminder: You do this at your own risk. A failure to flash correctly may brick your DCT module and render your car inoperable. Make sure you have an appropriate cable to flash if you do proceed.****
    1. Make sure your battery is good or you have a charger connected. Would recommend having a battery charger attached.
    2. Connect appropriate cable to obd port and computer.
    3. Load WinKFP software
    4. Press F1 for comfort mode
    5. Press F3 for update ZUSB
    6. Select ECU GS40
    7. Press F2 to select ZUSB
    8. Select ECU GS40. There will be ZB numbers to select from. Select 7845773.
    9. Select ok.
    10. You should see at the top the Assembly Identification number 7845773 now.
    11. Press F4 to enter your VIN.
    12. Select ok.
    13. Select Done F8.
    14. Press F3 for Program.
    15. Pop up window will give you the number of times left to flash ECU. Select ok.
    16. Wait until flashing reaches 100%. Pop up window will again appear giving you the number of times left to flash ECU. Select ok.
    17. Once flashing again reaches 100%, it should notify that programming is done. Select ok.
    That should be it. I verified the update in INPA.
